Differences between CH-46D and CH47D ?
    January 2006
Posted by Wirraway on Sunday, August 16, 2009 10:23 PM
I had an old CH46D Seaknight kit that I was going to use in a diorama, try and pass it off as a RAAF Chinook.
Are the external differences significant ?  If its something simple, I may be able to scratchbuild/modify.  If its anything significant, I wont use it.
"Growing old is inevitable; growing up is optional"
" A hobby should pass the time - not fill it"  -Norman Bates
GIF animations generator gifup.com
    January 2009
Posted by fermis on Sunday, August 16, 2009 10:29 PM
 I'm not a huge chopper guy, but, I'd say the similarities end at them both being twin rotors, and would imagine that trying to get one out of the other would be a major task. Your best bet would be to find a Chinook kit.
    September 2015
Posted by Aaronw on Sunday, August 16, 2009 10:58 PM
Yeah, quite a difference, some of the more obvious:
the CH-47 is quite a bit larger
the CH-46 only has sponsons at the rear, the CH-47 has full length sponsons
the CH-46 has its engines burried in the rear pylon, the CH-47 has "pods" mounted above the fuselage
the landing gear is different between the two
I don't think it would be at all practical to try and convert a 46 to a 47.
    June 2003
Posted by Avus on Monday, August 17, 2009 1:13 AM
Sign - Ditto [#ditto]
Briefly they are two completely different airframes!
I'd be like pretending a M-47 "Patton" to look like a Panzer VI "Tiger I" (like they do in some movies!), well not quite that drammatic.
Klaus
Thanks to ImageShack for Free Image Hosting
Posted by Melgyver on Monday, August 17, 2009 7:08 AM
Pretend you are a movie producer and mix them up!  They used H mode Hueys in place of N's they took off in and one of the N's turned into a 412 in "Behind Enemy Lines".  I can't remember the last movie they mixed up the 46's and 47's.  Tommy Lee Jones was defending Samuel L. Jackson for killing civilians during a Embassy withdrawal, based on a real story.
Clear Left!
Mel
Posted by HeavyArty on Monday, August 17, 2009 9:53 AM
As stated above, they are two totally different helos.  Here is a comparison from Global Security.org
Posted by J.H. Primm on Monday, August 17, 2009 7:53 PM
 That would be "Rules of Engagement"
Posted by J.H. Primm on Monday, August 17, 2009 7:56 PM
Why not just buy one of the Italeri or Trumpeter '47s?
Both are reasonable facimiles of the real item and they aren't overly expensive.
    January 2006
Posted by Wirraway on Monday, August 24, 2009 5:51 AM
I think I'll just make it as a Marines version, if I can find some decals.  The kit decals are the cheesiest, most out of register, blurred rubbish I've ever seen. Worse than Kitech.  The box art looks just like the 1/72 Fujimi kit, but all the writing is in Korean.  The Idea model company- never heard of them.  It was part of a bulk buy from e-bay.
    August 2005
Posted by Phil_H on Monday, August 24, 2009 6:26 AM
Hi Paul,
IDEA was a Korean company from the mid-late 80's which "cloned" many kits from Hasegawa, Fujimi, Italeri etc.
I think in many cases they just recast the sprues to make their mould masters. Have a close look at the parts - earlier kits in their range suffered horribly from huge sink marks, shrinkage and "short shots". Fit of parts is poor and the parts may appear roughly finished. Clear parts may be cloudy and indistinctly moulded. In some cases box art is nearly identical to the original (but poorly copied), with Korean writing.
    September 2015
Posted by Aaronw on Monday, August 24, 2009 2:48 PM
I'm not sure what is currently out there for decals, but Microscale did some aftermarket decal sets for the CH-46.
    January 2006
Posted by Wirraway on Monday, August 24, 2009 3:49 PM
 Phil_H wrote:
Hi Paul,
Actually Phil, I'm pretty happy with it, (decals aside) considering it only cost me a few bucks.  Some of the hardest plastic I've ever worked with !  Thanks for the info though.
Posted by J.H. Primm on Monday, August 24, 2009 4:01 PM
 Wirraway wrote:
 Phil_H wrote:
Hi Paul,
I beleive the kit in question IS a knock off. I bought a couple of them in 1988 when I was stationed in Korea. There are some subtle differences between the Fujimi kits though. They don't have quite the level of detail that the Fujimi kits do.
 And you are correct, the decals are lame...better to check your sources for appropriate markings. There were at least two seperate CH-46 after market decal sets in 1/72nd but not sure if they are still available. I used a set on the horrid AirFix incarnation of the CH-46 / BV-107 in the early 1980s and the sheet was the best part of the build! Sort of like putting lipstick on a pig.
    February 2007
Posted by Geomodeller on Thursday, September 24, 2009 9:16 AM
 Wirraway wrote:
...if I can find some decals...
If you are looking for something a little different, there is a fairly new sheet of markings for the Royal Thai Navy from Siam Scale:
Siam Scale decals are very cheap and excellent quality.
    August 2006
Posted by HawkeyeHobbies on Thursday, September 24, 2009 10:58 AM
Civilianize it and make it into a firefighting or rescue aircraft!
Gerald "Hawkeye" Voigt
    September 2009
Posted by Traitor on Friday, September 25, 2009 3:58 PM
Im a n00bie to models, so dont bash on me to bad. could he put the crappy stickers on, let them dry, then paint over them like an old civilian conversion? maybe have some of the old military paint showing through?
[quote user="RESlusher"] Nothing like seeing "two palm trees humpin' a garbage can"!! That's what we called the heavy lift guys when I was on an EH-60 at Fort Carson back in '91. [/quote] I'll never look at garbage cans the same again.
    June 2003
Posted by supercobra on Friday, September 25, 2009 7:16 PM
I don't think any military CH-46s have ever been converted to civilian use.  The civilian birds you see that look like 46s were built as civilian craft - forget the designation - BV-107?  Would work as a "what if' Mad Max or Wingman type scheme though.
    September 2015
Posted by Aaronw on Friday, September 25, 2009 7:39 PM
Columbia Helicopters has bought a bunch of ex Canadian Forces Labrador / Voyager, they may not be "CH-46s" but they are military. I have also seen a few of their helicopters with the CH-46 window configuration instead of the commercial 107 window configuration.
The mad max theme seems more reasonable as I can't see a commercial operator flying a CH-46 with painted over markings like some ex-police cruiser bought at auction.
    January 2003
Posted by leemitcheltree on Saturday, September 26, 2009 12:50 AM
I'm sure that there's someone out there who can correct me...but I don't think that the RAAF have CH-46's...and it's the Australian Army that has CH-47's.
As noted, the CH-46 is MUCH smaller than the CH-47...a completely different airframe...same general layout, but smaller.
Cheers, LeeTree
Remember, Safety Fast!!!
