Black Hawk Engine *~DONE~*
    July 2009
Posted by Axel Smith on Monday, September 21, 2009 6:56 PM
Hey, I'm working on a 1/35 scale black hawk, and i was doing a little detailing on the engine, and i was wondering if anybody had any good pictures of one, or knew where to find some.  I tried google images, but there weren't any good ones.  Any help would be fully apreciated! Thanks!
- Alex
'Verily, this vichyssoise of verbiage veers most verbose, so let me simply add that it's my very good honor to meet you and you may call me V...'
    January 2007
Posted by rotorwash on Monday, September 21, 2009 8:02 PM
Alex,
  Check this walkaround on Prime Portal.  maybe there is enough there for what you need.  There are a bunch of other Blackhawk walkaround there as well that might help.
     Ray
http://www.primeportal.net/hangar/gino_quintiliani/uh-60a_med_walk.htm
    July 2009
Posted by Axel Smith on Monday, September 21, 2009 8:10 PM
Thanks Ray, certainly a good start. Much Appreciated Approve [^]
- Alex
    July 2009
Posted by Axel Smith on Monday, September 21, 2009 11:10 PM
Okay, so far, what I've pretty much done is add a few scratchbuilt details and wires, some found on refrence shots, and others just left up to my extensive overactive imagination.  But i have a question... In all of the pictures I've seen of the engines, they're always different.  And I don't mean like this one has a few more wires or something, but i mean DIFFERENT. Same original shape, but some lack a lot of details found on others an visa versa.  I just wanted to know if there is a reson for this, or if it is just some sorta conspiracy to mess with my head...
- Alex
    April 2004
Posted by Screaminhelo on Tuesday, September 22, 2009 6:44 AM
 rotorwash wrote:
Alex,
  Glad they helped.  here's a few more:
 http://www.stiefelmaier.com/images/nellis_2005/slides/blackhawk_engine_filtered.html
http://www.aircraftresourcecenter.com/AWA1/101-200/walk158_MH-60G/part3/walk158C.htm
http://www.defenseindustrydaily.com/images/ENG_T-700_from_HH-60G_lg.jpg
http://www.scribd.com/doc/7273094/Walk-Around-n19-UH60-Black-Hawk
Just a couple of points.  The first link here is not a T700 series engine.  The last link to the walk around provides some decent info.  Some of the differences that you are seeing could be a result of the slightly different configuration between the engine installation on the right versus the left side (primarily the routing of the bleed air line for the starter on the right side coming over the top of the engine and the particle duct on the left side being outboard of the engine).
Here is a link that shows the engine on a stand without the duct installed.
T700
Mac
I Didn't do it!!!
    January 2007
Posted by rotorwash on Tuesday, September 22, 2009 7:36 AM
Sorry if I led anyone astray.  I know better than to post links to systems I don't know that well. Could someone tell me what type of engine that link actually shows?
    Ray
As an note, GE's site claims the T700 can be found in all these aircraft:
  • AH-64
  • UH-60L
  • AH-1W
  • SH-2G
  • UH-1Y
  • SH-60
  • HH-60J
  • MH-60G
  • MH-60K
  • AW101
  • NH90
  • S-92
  • MH-60R/S
  • UH-60M
However, this doesn't look anything like the photos of a T700 off the airframe:
[img]http://
From Drop Box
Is it just the ducting that's throwing me here or are there multiple variants of the engine?
    August 2009
Posted by A10wrthg on Tuesday, September 22, 2009 2:18 PM
also try squadron's UH-60 walkaround
NYFAIM
Posted by Melgyver on Tuesday, September 22, 2009 4:46 PM
Ray,
I think what you are seeing most on in the picture posted is a "blower" and ducting, for what I don't know, maybe to cool the exhaust.  You can see the main engine case buried behind and below the "blower".  It looks to be taking bled air from the compressor section, small duct coming up under the green wire.  This would be cold air and would make sense mixing with the exhaust gases and cooling them.  Purely conjecture on my part!  It ain't a Huey!
Clear Left!
Mel
    July 2009
Posted by Axel Smith on Tuesday, September 22, 2009 4:58 PM
Dang... You helio guys know everything! Laugh [(-D]
- Alex
    July 2009
Posted by Axel Smith on Tuesday, September 22, 2009 5:34 PM
Okay, here are some shots (not finished yet) but could you guys tell me what you think? It's not completely accurate, I know. More of a compilation of different pictures I've seen. But is there anything really important to fix? Just wanna know if I'm relatively on track.
View from top (still have to do a little work on the screen):
Top of the Engine:
Right:
Bottom:
Left:
Picture for the scale size:
- Alex
    January 2007
Posted by rotorwash on Tuesday, September 22, 2009 6:25 PM
Axel,
  Lookin' pretty good.  The soldier in that last pic looks like he has a T700 jetpack!
    Ray
    April 2004
Posted by Screaminhelo on Tuesday, September 22, 2009 9:00 PM
    Ray
  • AH-64
  • UH-60L
  • AH-1W
  • SH-2G
  • UH-1Y
  • SH-60
  • HH-60J
  • MH-60G
  • MH-60K
  • AW101
  • NH90
  • S-92
  • MH-60R/S
  • UH-60M
[img]http://
From Drop Box
The only ones that I am not sure about are the AW101 and the  NH90.  The others all use the T700 series engine, although various models within the series.  The M1 even uses the same basic engine!
In the picture, you are looking at the left engine on an Apache.  The large duct (ips duct) is for the inlet particle separator.  The bleed air tube below the green wire is for inlet anti-ice, at least it is on the Hawk and I imagine that it would be the same for an Apache.
Alex-
The engine is looking pretty good.  What comes in the kit is a pretty good starting point but some of the proportions are off, but that would really be getting into the nitty gritty, so I'll just throw out a few ideas to help busy it up like a real engine.
You could use some wire or fine solder to represent fuel and sensor lines on the engine.  The ips duct is made of fiberglass and is sort of a coffee color.  On the foreward portion fo the engine there are four wire harnesses, green, yellow, blue and white (just don't go crazy with them, they each only connect in a few places).  You could easily just pick out a couple of items in black and use a couple of metal shades on the core engine and it would really pop!
I can't do it now, but when the next phase starts, I'll try to remember to get some shots of the engines on the stands.
I hope to have been of some help.  Feel free to ask any questions or PM me for more info.
Mac
I Didn't do it!!!
    July 2009
Posted by Axel Smith on Tuesday, September 22, 2009 9:22 PM
Thank helo, that'll really help make some parts start out. I will get to work on that as soon as I can.  I found some good refrence shots of the colored wires in the front, and i'll try not to go overbord on them. Whistling [:-^]
- Alex
Posted by Melgyver on Wednesday, September 23, 2009 7:44 AM
Screaminhelo,
 Good eye on the Apache engine,  I should have noticed the "wing" he was standing on.  I was focused on the engine area.  Couldn't see the forest for the trees kinda thing!
Clear Left!
Mel
    January 2007
Posted by rotorwash on Wednesday, September 23, 2009 8:26 AM
Mac,
  Thanks for all the info. So if it's not a T700, what is this engine and what kind of aircraft is this?
   Thanks,
           Ray
From Drop Box
" border="0" />
    June 2003
Posted by supercobra on Wednesday, September 23, 2009 6:26 PM
Here are some pics of the installation in an AH-1W.  As mentioned the duct on top as well as the exhaust heat shields on the back will differ depending what it is installed in and the left side of the engine is very different than the right.  Seems most of my pictures are of the port side.  The engine detail in the 1/35 MRC AH-1W looks better than the H-60 kit but I don't know if they are scaled the same.
    June 2003
Posted by supercobra on Wednesday, September 23, 2009 6:28 PM
More from an AH-1W:
    July 2009
Posted by Axel Smith on Wednesday, September 23, 2009 9:07 PM
WOW! Shock [:O] Thanks for all the pictures cobra!
Hopefully I will post another update tonight, I've been hacking away at the engine, and I will post some pics before I paint any new peices...
- Alex
    July 2009
Posted by Axel Smith on Wednesday, September 23, 2009 10:32 PM
Update: I've added some scratched parts, but nothing is really painted yet.  I just want to get your guys oppions on if it is good or bad or incredilby inaccurate (hopefully not).  I've painted some of the upper engine, the grey and brown, found in my refrence pics.
Sorry if its a bit pic heavy
I put in the picture of the back, because I'm not sure how I'm going to display the model yet. I'll either close the model up, open it and display it. So do you guys think it would be worth it to scratch a backing to the engine?
- Alex
    January 2004
Posted by Mogwa on Thursday, September 24, 2009 8:12 PM
UH-60 Crewchief / Technical Inspector and Modelling Addict
    July 2009
Posted by Axel Smith on Thursday, September 24, 2009 8:26 PM
Oh Whoa. Thanks Mogwa! Very very much apprecited! That'll really help! Shock [:O] Big Smile [:D]
- Alex
    July 2009
Posted by Axel Smith on Thursday, October 1, 2009 12:33 AM
Okay, the engine is Primarily complete, i just need to do a bit of drybrushing, and a balck wash.
Comments and Crits welcome
- Alex
    December 2008
Posted by GRANT ED on Thursday, October 1, 2009 3:42 AM
Hi Axel. For what its worth I believe the ducting you were asking about at the start of the thread is ducting for the air powered engine starter. I work on the SAAB 340 which has the civil version of this engine fitted (CT-7). The air starter is a helicopter only thing. You will notice in some pics the ducting is gone and some rather heavy wires run to that area. These power the electrical starter/generator which is fitted in that case.
    April 2004
Posted by Screaminhelo on Tuesday, October 6, 2009 8:05 PM
Nice work Axel!  Rivet counters won't be pleased but this Hawk crewchief thinks it looks pretty good.  You have created the illusion of the engine.  I do want to make some good reference shots of the engines when the next phase starts and anyone will be welcome to them when I get them.
Mac
I Didn't do it!!!
    July 2009
Posted by Axel Smith on Tuesday, October 6, 2009 8:08 PM
Thank you Big Smile [:D]
And I know that rivet counters won't think its that great... but I'm not that picky.  I just wanted to add a little detail to the engine, I didn't like the OOB version.
- Alex
    April 2004
Posted by Screaminhelo on Tuesday, October 6, 2009 8:17 PM
OOB gives you a general idea,  but the proportions are all wrong.  All things considered though, it is a really good kit.  Most items to be fixed can be handled with simple techniques.  I still have one on the bench from a few years ago that drove me nuts trying to 'make it right'.  One day I will pick it back up and not be so picky and not compare it with the 1/1 scale ones at work.
Mac
I Didn't do it!!!
    July 2009
Posted by Axel Smith on Tuesday, October 6, 2009 8:23 PM
Yeah, well I'm not that picky about it being exactly right yet... but I am making a few changes throughout the build... and I know that the porportions of the engine and some other stuff is wrong, but I didn't want to scratchbuild the entire engine, so I just tried to add some detail to make is look a bit better.  I also had to copmletely strip the interior, cause I started it when I was 11 and didn't have any scratchbuilding/correcting experience.  So it was started OOB, shelved for 3 years, and now I'm picking it up as a side project... trying to add some more detail and such.
- Alex
    January 2007
Posted by rotorwash on Tuesday, October 6, 2009 9:11 PM
Alex,
  So you are only 14?  Wow, that is some great work regardless, but I'm not that good at scratchbuilding and I have a couple of decades on ya.  Great work so far, I can't wait to see her finished.
    Ray
    July 2009
Posted by Axel Smith on Tuesday, October 6, 2009 9:15 PM
Yup. Only 14. Well... 15 soon. But don't plan on her being airborne anytime soon. She's more of just a side project I'm working on in between other stuff. The interior isn't even finished yet. Haha. But if you want I can post pics.
- Alex
