Matchbox AH-1G in 1/72
Posted by firejoel on Tuesday, November 3, 2009 6:41 PM
I know this is an old kit, but it's another ebay miracle.  I need some help with the turret.  It's the original style turret with the single minigun.  I want to modify it to the later style turret with the minigun and grenade launcher, and I need some help.  Is the best way to fill with putty or to scratch an entire new turret.  Better yet maybe someone makes a complete turret in resin? Any info would be a great help.
    September 2003
Posted by Helo H-34 on Sunday, November 8, 2009 1:42 PM
 Hi firejoel
I'm not sure if my post is of much help , but I guess it probably would be easier to just fill the opening for the single turret with putty as you already suggested and drill/cut/file two new openings for both minigun and grenade launcher . I don't know of any resin sets available in 1/72 scale , I do have cobra company's 1/48 AH-1G back date set which includes a new resin turret .
On another issue ; I have two 1/72 matchbox AH-1J's sitting under the bench , I put them together a while back but the project stalled when I noticed that the oil radiator beneath the two exhaust cones is undersize and doesn't reach the outsides of the engine housing .
I'm not sure how to fix it now , I may have to try and carefully remove both radiator pieces and add some plastic strip to each side and sand and contour eveything in and hopfully put it back in position .
If you don't already have it , Squadrons AH-1 Cobra walk around book is a great resource .
Sorry I could not be of more help , good luck with your build , perhaps some day I'll get around to finishing my two Cobra's .
        John .
    June 2008
Posted by lewbud on Sunday, November 8, 2009 2:10 PM
I'd fill the slot(s) with strip styrene and then cut and sand to shape.  Scratching it shouldn't be too hard provided you can find the correct diameter tubing.  Hope this helps.
Buddy- Those who say there are no stupid questions have never worked in customer service.
Posted by DDonSS3 on Sunday, November 8, 2009 10:22 PM
Maybe this will be helpful:
