Question for the Huey junkie's
Posted by Anonymous on Saturday, December 12, 2009 8:48 PM
So, I built Panda's UH-1N, and did some serious damage to the body(intentionally), and will be showing it being towed on a UN trailer, somewhere in the mideast. I will be securing it to the trailer with binders and chain, but I need to know how they would secure the rotor blade. I have seen them tied down before, but I'm not sure how to make one. Thanks as always for any input, I will post pics soon.
Posted by Melgyver on Saturday, December 12, 2009 11:02 PM
brutus,
I never loaded a Huey on a truck trailer before, but stateside they would pulled the rotor blades and mast becasue of bridge and overpass clearances.  Since you said this was in the middleast I guess you could get away with leaving the rotors and mast on.  You could show some 1/2 in. rope looped over the main blades and tied back to the front of the skids and over the tailboom making the rotors "level".  I've seen some canvas "socks" slipped over the blades with 1/2" in. rope attached.  Sorry no pic's for you.
Clear Left!
Mel
Posted by grandadjohn on Sunday, December 13, 2009 4:24 AM
Saw one Huey on a truck while stationed at Ft  Stewart, the rotor blades were tied down as Mel described
    June 2003
Posted by supercobra on Sunday, December 13, 2009 8:58 PM
Don't recall ever seeing socks used on a UH-1N.  The tip of each main blade has a small square tab sticking out with a hole in it.  The tie down is a strap with a hook on the end that goes through the hole.  I've got pictures of it I'll try to find.
    April 2008
Posted by Retired Gunpilot on Wednesday, December 23, 2009 6:42 PM
If the rotors are to be left on what most do when they haul it is tie the rotor to the tailboom in a flat horizontal position and then tie the front blades to the two skid toe rings in the front or to the flat bed trailer. That way it will normally pass under wires and bridges. I have seen many hauled this way in Lousiana on the back of a flat bed. We stopped often though to make sure the tie downs did not loosen up. We had a L3 Longranger come loose at the front and when we went through a bridge that had the suspension on the top the front blade caught one of the bridge;s cross-beams and ripped the entire helicopter off the back of the flat bed and up into the girders. It was totalled. Crying
Charlie
