How are you guys striping your tail rotors?
    January 2006
Posted by dirkpitt77 on Sunday, March 13, 2011 2:54 PM
  Hey guys,
   Working on the Academy 1/48 500MD ASW kit, specifically the tail rotor.  I masked off a good section of the ends and painted red first, as the pattern is going to be a red-white-red.  Would you just mask over the red, leaving a narrow stripe in the middle so you can airbrush white, or what?  It came with orange decals for it, but I wanted to change it up a little.  I was just wondering, other than decals, if you had a method in particular for that.
                                       Thanks!
                                               Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    May 2008
Posted by Boba Fett on Sunday, March 13, 2011 3:07 PM
ALWAYS paint the lighter color first. I would have done this: Spray the entire thing white (well, within reason) mask off the read area, spray, then mask off the red/white areas and spray the inside of the rotor black or whatever color you're using.
    July 2004
Posted by stikpusher on Sunday, March 13, 2011 3:32 PM
Ditto
Like he said, white before red. BIGTIME! But I have been lucky in that most chopper kits I have done have decals that cover that marking...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2006
Posted by dirkpitt77 on Monday, March 14, 2011 12:58 PM
   Yeah, I thought of the "lightest color first" thingy about 1/2 an hour after I sprayed the red.  Oh well.   I think I'm going to try to mask it with some clear tape to get the line thickness right.  We'll see what happens.
    May 2008
Posted by Boba Fett on Monday, March 14, 2011 1:14 PM
you could just strip it... that, or mask off the red, use a primer, then spray the white. it might cause paint buildup, but the red won't bleed through the white
    January 2006
Posted by dirkpitt77 on Tuesday, March 15, 2011 10:37 AM
    Well, last night I hit it with the white.  I masked off the red leaving a stripe in the middle, and shot some white on it.  It actually turned out ok.  I was using MM Acryl flat white, and as I think most know, the Acryl's dry pretty fast out of the airbrush.  That was my saving grace.  I was able to throw a second coat on within a minute or two.  It's not gonna win any awards, but it looks good enough for me.Yes  Thanks for the support though, guys.   :)
    October 2009
Posted by Ti4019 on Saturday, June 4, 2011 11:46 PM
and dont forget the erosion strip on a lot of TR's. On a USA helo with yellow tips you should also underpaint with white , yellow doesnt cover well.
If you aren't having fun, you're doing it wrong! Build to please yourself and they will flame you every time!
