UH-60l and transporting
    March 2008
Posted by phoneguy on Tuesday, August 16, 2011 4:39 PM
Got a question for all you UH-60 guru's.  I have been thinking on how to display my 1/35th scale UH-60l when I get started on it.  If a 60 carried a load of say a hummer, would they also carry the men to man it inside?
I've been thinking of having the 60 in a hover position to drop the hummer and have some figures repel down rope.  It that fact?  Any input would be appreciated.
thanks.
On the Bench:
B-29 Superfortress
1/48th A-6E Bomber
Welcome to Wal-Mart:  Get your stuff and get the HECK Out!
Shut up, I'll Keel U!
    September 2010
Posted by Hookdriver on Tuesday, August 16, 2011 5:57 PM
I'll preface this by saying that I fly chinooks, not hawks. The Blackhawk is advertised as being able to carry a 105mm howitzer (approx 5000lbs) it's crew of 6(approx 1500lbs) and 30 rounds of ammo (660lbs). So it should be able to carry a non up-armoured humvee (approx 5500lbs) and a crew of 4 (approx 1000lbs).  These figures would  be at sea level on a standard temperature day of 15 degrees celcius. Hope this helps, I look forward to see this built.
NSDQ!
Posted by HeavyArty on Tuesday, August 16, 2011 6:25 PM
As Hookdriver says above, yes, it could carry the vehicle and crew.  It would not be common to have the crew repel down after the HMMWV though.  The helo would usually lower the HMMWV down, disconnect, then fly off a few meters and land to let the crew out.
Some proof:
And with an M102A1 Howitzer:
    March 2008
Posted by phoneguy on Tuesday, August 16, 2011 8:19 PM
thanks for the reply.  just trying to get different ideas.  i will keep the pics in mind.  u mind if i save them?  i'm not a vet, but some of my nephews are.  If i could have passed I would have chosen the Marines.  sorry if i offended anyone.
On the Bench:
B-29 Superfortress
1/48th A-6E Bomber
Posted by HeavyArty on Tuesday, August 16, 2011 9:09 PM
No problem on saving them, I just found them on the web.
I too am about to start a UH-60L MedEvac in 1/35 using the Academy Blackhawk, Werner's Wings MedEvac Conversion and new Blackhawk decals.
Good luck on your build and be sure to post some pics once you get started.
    March 2008
Posted by phoneguy on Wednesday, August 17, 2011 3:59 PM
HeavyArty
Thanks, been thinking about adding some lights also, make it real interesting.  Ill have to do some thinking some more on it.
On the Bench:
B-29 Superfortress
1/48th A-6E Bomber
    March 2008
Posted by phoneguy on Wednesday, August 17, 2011 4:23 PM
HeavyArty
Thanks, i have tinkering with the idea of doing some lighting on it also.  thanks for all the input.  will post pics as i go.
On the Bench:
B-29 Superfortress
1/48th A-6E Bomber
    April 2004
Posted by Screaminhelo on Saturday, August 20, 2011 9:58 AM
You may consider doing a gun raid.  The Hawk slings a 105, ammo and gun crew.  They drop the equipment and crew.  The gun crew does a fire mission and the Hawk comes back and picks them up.  Gino can shed much more light on the subject but I remember doing this up near Bragg years ago and having lots of fun doing it.
As far as load capabilities in general are concerned, the cargo hook on a L can carry 9k lbs.  Stateside, a L has about a 7k useful load capacity.  A standard HMMWV is no problem at all but not an up armored or TOW.
BTW Gino, I am very interested in how that MedEvac set works out.  Maybe they will do an HH-60M interior before too long as well.
Mac
I Didn't do it!!!
    March 2008
Posted by phoneguy on Tuesday, August 23, 2011 6:49 PM
Screaminhelo
Gino anymore info?  how do they sling it?  what do you think about that dio?
On the Bench:
B-29 Superfortress
1/48th A-6E Bomber
Posted by HeavyArty on Tuesday, August 23, 2011 7:14 PM
I too have a plan to slingload an M102 Howitzer.  Here is a diagram with and without the M-22 Cargo Bag for ammo.
This link will also show you the FM for sling-loading howitzers.
    March 2008
Posted by phoneguy on Tuesday, August 23, 2011 8:16 PM
thanks, ill have to print them off and blow them up.  how many personal crewed the 102/105.   did the 102 see service in the last wars?  and does the 105 sling the same way?
On the Bench:
B-29 Superfortress
1/48th A-6E Bomber
    March 2008
Posted by phoneguy on Tuesday, August 23, 2011 8:19 PM
did they still para-drop the gun and crew or just land one at a time?
On the Bench:
B-29 Superfortress
1/48th A-6E Bomber
Posted by HeavyArty on Tuesday, August 23, 2011 8:49 PM
The M102 has been used as recently as 2008 by NG units in Iraq.  It is a 105mm howitzer.  The current 105mm Howitzer is the M119A2.  Both of these are at the FM link and it shows how to rig them.
For 1/35 models, the M102 is available from AFV Club in plastic at around $15.  The M119A2 is only available from Mouse House Enterprises out of Australia in resin at about $75 plus shipping.
I recently did the M119A2.
A 105mm towed arty piece usually has a crew of 4 Soldiers or Marines.
As to Airborne ops, yes, M102s and M119A2s are still para-dropped on pallets.  The crew parachutes in separately.
Here is an M101 105mm Howitzer (WWII and Korean War era) rigged on a pallet for Airborne ops.  Actual para drops are not that common any more.  They are pretty much only used in training and haven't been used in combat in quite a while.
    March 2008
Posted by phoneguy on Wednesday, August 24, 2011 4:03 PM
thanks for the info. will have to see what is affordable (meaning ill have to work some ot).  hope i can call on you for help?
On the Bench:
B-29 Superfortress
1/48th A-6E Bomber
    April 2004
Posted by Screaminhelo on Friday, August 26, 2011 1:51 PM
This could be a tough dio in 1/35.  As you can see in the pictures, 10k lb sling legs are not very big compared to the aircraft.  They are about 1 1/2" thick (give or take), so scale sling legs may be a little weak for a model that size.  That being said, you do have four legs to support the weight of the model and the weakest point may be at the aircraft.  I think that the key here may be in concentrating getting it to look right rather than scale accuracy.  Let me know if I can help with info from a crewchief's perspective.
Mac
I Didn't do it!!!
    March 2008
Posted by phoneguy on Friday, August 26, 2011 3:03 PM
thanks, if i need some counsel i will look you both up!  trust me!
On the Bench:
B-29 Superfortress
1/48th A-6E Bomber
