jimz66,
A grab and dash is what we call it when we don't have much time to recover a survivor and simply grab them, and get airborne again. It's just a term most of us in the squadron us to describe the event. Sometimes you have time to upload the survivor or do a long hoist recovery. A "grab and dash" is plopping down in the LZ, grabbing them and then blasting out of the LZ. In the mission I mentioned before, we had so little fuel and the density altitude was so high (14,600ft) we only had a small window to land (sort of) grab the survivors, and then get the hell off the Ice ridge.
Drooping the main rotors. Let me set this up to help explain. So here we are trying to land on this "LZ" up at 14,600 ft to pick up these two guys whose buddies had just skied off the top of the mountain to their deaths. One hade HAPE pretty good, and the other was hypothermic. We did the computations and figured that after we dumped a bunch of gas, we would need lets say 96% power to hold a hover at that altitude. The problem was that we would only have 98% available. Let's say a downdraft dumps on you, where are you going to get the power to maintain the hover? In this particular mission, we made somewhat of a running landing on the ice ridge (which was about as long as our HH-60). On the approach we drooped the rotors. That means, the engines are giving all they can, and the rotors speed is maxed out, yet you still increase the collective imput coming in to the flare. The engines can't give you anymore power, and the rotors can't turn any faster but yet you're increasing the pitch on the main rotors....the result is drooping the rotors...the rotor speed starts to slow down and if you don't get right on it, the Helo goes down as well, since you don't have the altitude to back off the collective and increase the rotor speed. I hope that makes sense.
Anyway, we plopped down on this ice ridge and as our pilots decrease collective to settle on the ice, the right side of the Helo goes crunch and dips to one side...not good. Before this happend as we were coming in, these two yahoos start running straight for the Helo totally busting our option for a go- around. Anyway, we get them onboard, and now REALLY need to get going due to our fuel state (remember we dumped a bunch just to have the power to get into the site). The pilots try to pull her up into a hover, but at max power we could only get "skid light". So we skied forward and dumped her over the side of the ridge at about (I'm guessing) 15-20 Knots. When we cleared the edge of the ice ledge, we dumped the nose over to gain airspeed and we actually oversped the rotors on the way down.
Hope that I didn't complicate things further, and that you understand the terms.
