Guys, sorry for the delay, I just heard back from the Colonel this afternoon. Here's what he told me....
1--the tail code on both Cobras was EG, as they were detatched to HMM-263 as part of the 24th MEU.
2--Lead a/c used call sign Bolt 41, and carried the side number 41. Unsure at this time what side number the wingman carried.
3--Bureau #, he is checking for me on this, he recalls that the first three were 160 but does not know the rest off hand. Again, for the lead aircraft. My research shows this cannot be correct, however, since the very first Lot I AH-1W model carried bu.no. 162532, and as far as I am aware, the only AH-1s that carried 160- numbers were T models.
4--Loadout--Bolt 41 carried the following:
Outboard Left--100 gallon aux fuel tank
Inboard Left--LAU-68 7-shot rocket pod carrying flechette rockets
Inboard right--LAU-68 7-shot pod carrying HE rockets
Outboard Right--TOW missile launcher carrying two TOW missiles
Also carried a full load of chaff and flares in the ALE-39 dispensers mounted on top of the stub wings.
Wingman's loadout was the same except that in place of the TOW launcher, wingman carried an additional LAU-68 pod carrying white phosphorous rockets in case they had to do any FAC work, marking targets for the AV-8B's to take out during the rescue.
Both a/c carried 500 rounds of HEI ammo for the gun.
5--as someone already said, they did not have any NTS birds at that point. The two a/c both had the standard TOW sight unit mounted in the nose.
Wish I could get that bureau number for you, hopefully he will get back to me as promised. In the meantime, this is as close as I can get you for now. Hope this helps.
