Thanks. I just want to build a Huey (more likely 2 now) as I've recently been watching lots of Vietnam films and TV series like We Were Soldiers, Apocalypse Now, Air America, and Tour of Duty. They've inspired me to buy/build a Vietnam era Huey model and thus I bought the Revell 1/48 kit, but I've since realised that it's not the best kit in the world (lots of flash on small parts for a start), unfortunately the Italeri Bell AB 212/UH-1N kit seems to be more modern than having seen general active service in 'Nam, but despite that it looks slightly better in quality and is about the only other kit still readily available in 1/48.
I would have gone larger scale and bought a better kit of a Vietnam era Huey but I need it in 1/48 scale for a specific reason.
I'm not really looking for a high-vis one per se either, I just like the look of the HML-267 UH-1 scheme from the Revell kit and wondered if it was indeed a paint scheme based on a real UH-1 (which it appears to be although I can't find out anything about it apart from it's serial number/squadron).
For the Italeri UH-1N I'm basically looking for something that's not complicated to do and isn't the USMC grey they seem to use these days and also isn't the standard paint schemes the kit suggests (2 aren't US and the one that is a US scheme is of a Rescue chopper) - mainly because I can't shade/highlight and do panel lines very well, and to make the more modern USMC grey scheme look good I'd have to do the panel lines, so any dark, green/olive drab, sort of colour scheme will hide my poor painting skills a bit.
Not too keen on Navy dark blue/grey with red/orange though, looks OK but just not to my taste.
The USAF 20th SOS had a sand/green/dark green camo pattern during 'Nam judging by the pics I've just found (standard USAF pattern of the time as I understand it), which I feel is a little too complicated for me to make look good with a brush, and I don't have an airbrush and I've never used one.
I'm on a tight budget with both of these though (I've not bough the Italeri kit yet though) so buying a bazillion pots of paint just for a heli or two is out of the question.
So, I'll probably stick with that one from the photo taken at NAS Whiting Field, Florida, in 1982, it seems quite easy to do (with a bit of artistic licence), the base colour I can just spray as Matt Olive Drab (Humbrol #155 acrylic spray, unless there's a better colour Humbrol acrylic spray?) and go from there because the rest (besides a few details) is all decals by the looks of it.
Some of the decals I can get from the Fireball models AH-1G Part 2: Snakes with New Skins sheet, I think, might be too small though?. Not too sure how to do the numbers and the letters/numbers/stars on the tail, but they don't look too complicated and I might be able to make paper stencils or something for those, might even look into printing my own decals.
The Revell Huey is my first model kit in 10-15 years, and possibly the first of this type of model for 20, I used to paint/assemble Games Workshop models more than anything (and they're a bigger scale for a start). As a kid in my teens (20yrs ago) I did the usual Spitfire/Hurricane/Lancaster along with a Aerospatiale Dauphin (which I painted as AIrwolf, lol), a P38 Lightning and a B17 Flying Fortress and also I think I had a B24 LIberator, but they were all in 1/72 scale and were all done by brush with enamel paints (and you could tell).
I intend to do as little brush work as possible on the Huey(s), relying on an acrylic spray can for the base colour in order to keep it down to a nice and light and smooth layer or two.
What started out as a simple project has actually turned into quite a quandary though. Lol.
One thing I plan on doing after the main helicopter bodies are assembled is to make the weapons system removable (hopefully by using 6mm or 12mm M2 nylon screws+nuts) so I can take the entire weapons rig off (in 2 halves, one each side) and switch it between each of the Hueys (obviously using those M134's I'm buying from you rotorwash, the quad M60's in the Revell kit are terrible, I might as well use wire or something for the barrels, plus I think the M134 weapons system (M21?) looked better - you can't beat a minigun, or two).
And as I said I'm hopefully doing something to the UH-1N that means it won't be just a static display model, might end up doing it to the Revell Huey instead though (or maybe both), but I need to gather all the parts/decals/paints and also source some "special parts" to find out which kit they fit best before I proceed any further.
Anyhoo your help has been much appreciated and I'll post pics of progress/the finished helis when I can.
Many thanks.
