Thanks Gino.
No problem with keeping the "extras" in the same scale, the minigun set and figures (one has the M60) will all be 1/35.
Problem with the Dragon models kit is that it would be 8% smaller in the cabin area, and "those parts" that I'm putting in most of the kits I've currently got probably wouldn't fit. 1/32 might be a tight fit as it is for this Loach.
Basically if you imagine putting a box with the dimensions of (roughty) 35mm wide at one end, 25mm wide at the other end 55mm long and 35mm tall into the forward/engine area of a fuselage of any given helicopter kit then you'll see why I'm picky about the overall internal size of a model kit.
I think aside from the 1/35 Bell 47 (HTL-4) (which I know the parts fit in just right) and UH-1C I've got, the 1/72 Jolly Green and Sea King I've got will be a tight fit also, so I may end up just sealing them up and building them as normal. The 1/48 UH-1D may get sealed up also but obviously as I've painted it already I can't do much about the seam.
Plus I've just bought the Revell Loach kit. Lol.
I'm not a rivet counter anyway, as long as it looks like a Loach I'm happy (yes I would have preferred a Dragon Little Bird but it's not available currently and just a little too small). I just don't want the crew/minigun looking odd if I use 1/35 versions of them, which it sounds like they won't because I doubt anyone can tell by eye there's an 8%ish difference.
Should be a good little (not very complicated) build at least, like the 1/35 Bell 47. My Jolly Green has been fairly simple so far also but the Academy UH-1C is starting to give me nightmares, and so far I've only assembled the external weapons and the main body!!
