Doesn't stick
    February 2004
Doesn't stick
Posted by adrake2 on Sunday, March 7, 2004 10:14 AM
I need some help with the miniguns for my MH-60L project. I bought the MRC/Academy UH-1C "Frogs" for the vinyl ammo feed chutes, but I'm having trouble getting them to stick onto my miniguns. I used sheet sytrene for the feed ports on the minigun and I've used QuickTite Superglue and Testors Liquid Cement, but the bond is too weak and breaks off when I handle them. Banged Head [banghead] Any advice on how to get the Censored [censored] vinyl to stick?
-Aaron
    February 2004
Posted by Tailspinturtle on Sunday, March 7, 2004 12:06 PM
I don't think anything will stick vinyl to something else and allow handling. I suggest that you add the feed chutes last, using something like Future floor wax or a high quality white craft glue like Sobo, to stick it in place. You'll have to hold it there until the liquid dries, but at least it will dry clear and keep things stuck together if there' s no load on the joint. Depending on the contact area, there's a rubber cement trick that involves letting a coating dry on the parts to be joined; they'll stick when you put them together - unfortunately, rubber cement will also dissolve paint at a touch.
Posted by Anonymous on Sunday, March 7, 2004 2:04 PM
I have not tried this but what about a version of a contact cement? If you've made trees for dios you've likely used a Senic Cement that attaches the foliage to the trunks and the trunks are a fexible plastic or vinyl ... Anyone used that on vinyl?
Posted by Melgyver on Sunday, March 7, 2004 7:07 PM
I would be very careful and heat up a small piece of wire and stab it into the vinyl feed chute, maybe two pieces, to make a "plug" and drill holes in the mini gun to glue the wires in with super glue.
Clear Left!
Mel
    July 2003
Posted by oldhooker on Monday, March 8, 2004 12:28 AM
Hmmm... interesting subject!
I've always had success using "Shoe Glue" (very strong). It's ONE magic solution that made the 9 vinyl ammo chutes work when I scratched the Aurora ACH-47 (five .50 cal, two 20mm, two sections of 40mm)..... the other trick to making them stay connected, is NOT "handle" them after they're assembled. Smile [:)]
Take care,
Frank
    February 2004
Posted by adrake2 on Monday, March 8, 2004 11:14 PM
oldhooker,
I'm going to try the shoe glue trick. Do you have anymore information like, will it take paint? Does it need to have a large contact area?
Thanks everyone for the replies.
-Aaron
    July 2003
Posted by oldhooker on Tuesday, March 9, 2004 12:26 AM
adeake...
It doesn't take much to work, just the contact area's. Also, what little bit of glue that was exposed, took the paint just fine.
Good luck and remember to post some pictures! Wink [;)]
Frank
Posted by FITTER on Tuesday, March 9, 2004 7:36 PM
I once tried vinyl swimming pool repair cement to join the ends of a tank tread. It has not come apart, even after perhaps 25-30 years. I never tried it on styrene, though. It may be worth testing.
Another possibility would be automobile tire patch cement. I have not tried this one personally.
FITTER
IBTL
Posted by wibhi2 on Tuesday, March 9, 2004 8:14 PM
Ever try PVC cement? That stuff will pretty much stick anything together.
3d modelling is an option a true mental excercise in frusrtation
