Raised rivets on Revel's Merlin 101 - how do you get them back if sanded some out.
    December 2005
Posted by Stuart06 on Monday, April 6, 2015 1:46 PM
I am working on Revel's Merlin 101 and had to sand some joints so that you cannot see some gaps. Although I can re-scribe any panel lines, the problem is the raised rivet details. In 1:72 scale they are extremely small. All the rivets are raised so I don't thing a rivet roller will help (or would/could it?) What would be he best technique to get these rivets back. I was thinking of using dots of super glue, but worry about lining them straight and even? (is that the best method?)
Most of my friends are imaginary
Sell your watch, because time is money $$
In Canada hwy speed is measured by number of moose tracks per hockey goal.
Posted by HeavyArty on Monday, April 6, 2015 4:13 PM
Archer Fine Transfers has 3D Surface Detail decals that include rivets in various sizes.  They are made out of resin on decal paper and work very well.
You can check them out here:  www.archertransfers.com/SurfaceDetailsMain.html
    September 2012
Posted by GMorrison on Monday, April 6, 2015 4:17 PM
Really, I looked at a number of photos of the aircraft. Those are tiny little things in double rows.
I don't think glue will work. Check out Gino's link.
Dang though at 1/72 tiny.
EDIT: I read your OP more closely- you have most but not all of the rivets.
That makes it nearly impossible. Not to be a d*ck but if you want rivets you might just buy another one. And finish this one with them all sanded off. Maybe with those resin rivets too.
    December 2005
Posted by Stuart06 on Monday, April 6, 2015 6:01 PM
When I mean I have most of them, I mean that in a line of rivets maybe half of the rivets in that line has been sanded down where I needed to close the joint.
In a full line, perhaps the Archer things will work...
    June 2013
Posted by RobGroot4 on Tuesday, April 7, 2015 3:15 AM
In 1/72 if you sanded the remainder off and used a roller to "add them back" the eye likely wouldn't be able to tell they are indented vice sticking out under paint and a wash.  If you have an old model or some scrap plastic give it a shot.  If you don't have a roller-style riveter, you can use a pin vise and a needle to see how it looks, but I would recommend using a roller on your model for alignment and spacing.  Dymo tape (sold at office supply stores) works great as a guide for the riveting rollers.
If you opted for the archer transfers, I imagine they would be ever so slightly larger or smaller than the ones molded on the kit and you might need to replace the ones you saved anyway.
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    June 2003
Posted by supercobra on Wednesday, April 15, 2015 8:38 PM
A hacksaw blade also works well as a guide for getting a straight line and even spacing if you want to indent them using a needle.
    April 2004
Posted by Jon_a_its on Thursday, April 16, 2015 3:27 AM
The better rivet-rollers are shaped to more closely resemble the 'dimple', in that the point indents, creating a donut of raised plastic round the dent.
The skill lies in getting them even, & correctly spaced. Dymo tape, double-thickness Tamiya tape, PE templates will help. good luck
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    January 2010
Posted by Shawn M. on Thursday, April 16, 2015 12:20 PM
when I lost some on my fw-190 I used the archer rivets to bring them back, easy to use and turned out great
I love the smell of plastic in the morning
