Chinook
    February 2015
Chinook
Posted by Billmc on Thursday, October 8, 2015 10:00 AM
So i am building a 1/72 scale hobby craft chinook, its getting to the end of putting the kit together. Painting,for the one's who have built this, how did you mask it to paint?. This is my 2nd go around for the 1/72 scale. My prevous one was a trumpter, i painted before i glue the bodys together. Now i am trying it the other way. So how did you mask the side windows, the port holes? Or if you did not how did you work around them? Those round port holes do not glue very good, and can easly be push out, so is there trick??
Posted by HeavyArty on Thursday, October 8, 2015 10:22 AM
I haven't built that specific kit, but have built lots of helo models.  I completely build the fuselage and glue in any windows that can not be reached from the inside after the fuselage is closed up.  I then tape up the window from the outside with either masking tape or blue painter's tape.  Place a large piece of tape over the window and press it tightly against the glass being sure to press around the frame outline so it can be seen.  Then simply cut around th frame with a sharp xacto knife.  If the window can still be reached after closing the fuselage (like on cargo doors, pilots' doors, etc.), I will leave the glass out and tape it up from the inside before tacking the door in place.
Here is an example.
Front canopy, small jump doors, triangle window on pilots' doors, and chin bubble windows taped off from outside.  Cargo door windows, top greenhouse windows, and open pilots' doors windows all taped from the inside.
Hope that helps.
    September 2012
Posted by GMorrison on Thursday, October 8, 2015 10:37 AM
Another trick- I've done this on 1/72 aircraft including a CH-46:
put a blob of Elmer's on the window and work it around with a toothpick. It will pop off easily when you are finished.
