Build Log: 1/32 UH-34D Conversion
Posted by HeavyArty on Wednesday, March 31, 2021 10:09 AM
I am about to start on something I have wanted to do for a long time; a large scale (1/32) UH-34D conversion.
The finished product will be a USMC UH-34D from Vietnam which is currently at the National Museum of the Marine Corps in Quantico, VA; YN-19.  This helicopter has very long and storied history, which can be found here: https://www.freedomsflyingmemorial.org/index.html
I will be starting with the Fly Models Westland Wessex HC.2 kit, which is of a later British version with turbine engines.  The kit is interesting that it is a true multi-media affair with injected plastic, resin, PE, and paper parts.
I will be using a new product that will be available soon to backdate it to a USMC UH-34D with piston engine.  It is a 3D printed H-34 nose conversion designed by Oliver "Rotorman" at ARC and printed by Norbert from Reedoak Rubber Composites ( http://reedoak.com/ ) out of France, who do excellent 3D printed figures and accessories in multiple scales.  It is beautifully printed and extremely detailed.  A great piece.
More to come as I get started.
    May 2009
Posted by Pawel on Wednesday, March 31, 2021 12:51 PM
Hello Gino!
Another interesting subject - I'd be watching this one with interest. Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
Posted by midnightprowler on Wednesday, March 31, 2021 7:38 PM
Really looking forward to it.
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Posted by HeavyArty on Monday, April 5, 2021 8:21 PM
I have made a bit of progress.  It doesn't look like much, but it was time consuming.  The Fly Models kit is very detailed.  You start by adding all internal stringers and longerons in the rear cabin.   The vertical stringers weren't too bad as each was a separate part that you glue onto thin lines on the inner wall.  The longerons and parts around the windows are each individually cut to fit between the stringers.
Here is one side done, one to go.
They took some time, but it does look great when done.
Posted by midnightprowler on Tuesday, April 6, 2021 4:22 PM
Big beast i bet.
Posted by HeavyArty on Wednesday, April 7, 2021 11:51 AM
Yup, it is pretty big; about the same size as a 1/35 Black Hawk.
    July 2004
Posted by stikpusher on Wednesday, April 7, 2021 1:47 PM
I had no idea that anybody did a large scale one of these. This is too cool of a project!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    March 2013
Posted by LonCray on Thursday, April 8, 2021 7:43 AM
Gorgeous work as always; your helis are works of art.  Following!
Posted by HeavyArty on Friday, April 9, 2021 9:08 AM
Thanks gents.  Not much work on it this week.  The plan is to work on it most of the weekend, we'll see.
Posted by HeavyArty on Sunday, April 11, 2021 8:04 PM
Progress is moving along slowly. I have completed all the stringers and longerons on both sides of the cabin. After finishing them, you glue a bunch of triangular and diamond shaped PE bolt plates where they come together.
There was a minor issue with these PE plates. The instructions indicate a total of 33 of the diamond shaped plates. However, there are only 24 on the PE sheet. To rectify this, I left them off behind where the seats will be. You won’t see that area to tell they are missing.
Posted by HeavyArty on Tuesday, April 27, 2021 5:53 PM
Work continues, slowly.  Life and Hockey on TV (Go Bolts!) keep getting in the way of bench time.
I have continued with the cabin and cockpit area.  First off, the kit is inaccurate in the area where the lower front cabin wall and the cockpit rear wall meet.
This is how the kit has you build it.  It has a couple issues.
9c7046603152b1c7e11cad4f1aa2568273e03b12
To start, the cockpit rear wall comes down too far.  The kit has it even with the cockpit floor.  There is actually a step there.  I cut 5mm off the bottom of the cockpit rear wall.
Next, there should be a tunnel going from the cabin front wall through the cut out area to the ceiling that the prop shaft goes through from the engine to the transmission above.  You can see it in the below pic.
9f776aac7e86c5447d59f0329434c0302090ba37
Here is how I replicated it.  I cut off the bottom of the rear IP at an angle, then boxed in the tunnel with sheet styrene and added an access panel on the rear side.
0619fc33d97fccfd930d7e26c79bfb2d4c4942ba
656a61b02fefceb1a4b7d37d8cf4e2a60fd1c41b
5ea7c83123369d398252476be9cb296d5cd1cab3
Also, here is how the mesh will look on the nose section. I'm not sure how much details I will add behind the screens.  I am using a PE mesh from Royal Model (no. 469).  It is relatively fine and I don't think you will really see much through it.  We'll see.
8f84edc011f228bb34c4faa8f330d47e7dc607f9
Posted by HeavyArty on Friday, May 14, 2021 7:36 PM
I have a small update tonight. Not a lot done as I have been pretty busy w/life lately. My younger daughter graduated from college last weekend and was commissioned into the US Army as an ADA officer. She gets married next week, so I have been and will continue to be busy.
A very proud papa.
On to the H-34…
I have pretty much finished building and detailing the cabin and cockpit. I found that the cockpit floor was too long for the H-34 nose. The angled front firewall that separated the cockpit from the air intake grills area was falling across the middle of the grills. I cut the angled part off and glued it into the H-34 nose in the correct place.
IMG_1771
I then cut 1cm from the cockpit floor and angled the front of the center console to match the angle of the firewall. I will need to add about 3mm of styrene to the bottom of the firewall as the new position (further aft) raised it up as well.
 The H-34 IP is also included in the kit listed as “For Other Versions”.
IMG_1775
Lastly, I added details to the cabin side of the cockpit rear wall and the cabin front wall.
IMG_1774
That’s it for tonight.
Posted by midnightprowler on Saturday, May 15, 2021 7:19 AM
Congrats to your daughter, and great work.
    March 2013
Posted by LonCray on Saturday, May 15, 2021 9:25 AM
Yes, congratulations to your daughter.  May her career be long, safe and fulfilling.
Posted by HeavyArty on Saturday, May 15, 2021 3:17 PM
Thanks guys.
    October 2019
Posted by Tanker-Builder on Sunday, May 16, 2021 9:07 AM
First:
    Let me give you congratulations for your Daughter. Being in the service and a wife can be a strain. I know for sure. All three of mine got the " Military Flu" So I got one A.F., one Navy, and one U.S.M.C. All flyers. Husbands came later and the oldest is now single. May she have BOTH a long  Happymarriage and a long safe, career in the service.
      Now to the Chopper. That looks as fascinating as my French Helicopter. Lotsa of parts right? The Super Frelon is a big Model too. and I stopped on it till dry summer months get here. I want to paint it outside! The rotor blades are darned near as big a circle as the top of my A/C condenser fan opening!
 Are you NOT going to have the doors over the engine opening, or removeable, to show the power plant? I have never seen anyone do an exposed power plant on one of these types. How-come?
Posted by HeavyArty on Sunday, May 16, 2021 12:06 PM
Thanks and I'll pass on your words to my daughter.  I am very confident she will do well at anything she puts her mind to.  She is just that way; wonder where she got that from?
Glad you like the build so far.  It has been fun and will be quite big when done.  I built the Heller Frelon many years ago.  It is huge, but well detailed.  It should come out nice.
Tanker-Builder
No engine in this one; for a couple reasons.  One, the kit doesn't come with anything for the engine compartment and I don't feel like sourcing an appropriate radial engine, scratching everything that goes with it, and cutting apart the 3-D printed nose to make it all work.  The 3-D nose is pretty brittle and I don't think it would cut well either.  There is word though that Reedoak may have an open nose and engine compart in the works.  Also, I plan on making this an in-action bird, with a crew and disgourging Marines, so no open engine compartment.
    October 2019
Posted by Tanker-Builder on Monday, May 17, 2021 7:54 AM
Well Now!
    That sounds like a Plan to me! Note: Tell your daughter to take No Crap off of any man. She's going to have an uphill fight in the Man's world she chose. I definite Wish her Luck and Good Fortune. She looks Determined so there !
Posted by HeavyArty on Friday, June 18, 2021 8:12 PM
I have made a little bit of progress.  I completed the basic interior and haver painted it.  Waiting for paint to dry to proceed on that.
In the meantime, I have been working on the 3D printed nose.  It is very detailed, but missing the intake screens and internal parts that can be seen behind them.
I added the firewalls and a basic engine fan and drive shaft inside.  The engine fan is a little small, but for what you can see, it will do.  The firewalls are 0.020 styrene, and the engine fan is a couple left-over fans from a couple Tamiya M26 Dragon Wagon kits.
For the intake screens, I ordered PE screen from Royal Model; Medium Hexagonal Mesh (#469).  I made a template for the screens by enlarging a 1/48 UH-34 PE fret to 1/32.  I then used the paper templates to cut the Royal Model mesh.  It was pretty close and only required a bit of finessing to get them to match the openings on the 3D nose.
I also made a recessed "bucket" to place the exhaust pipes into.  I used a kit part for the wheel hubcap used on the British version that is excess to the UH-34.
More to come soon.
Posted by HeavyArty on Sunday, August 29, 2021 8:36 PM
I'm slowly making progress on this one.  I have been working on the cabin recently.  I installed wiring and the troop seats so far.  I made the seats out of the kit provided frames and fabric made from red card stock paper with the seat pattern printed on it.
I also have some of the detail pieces started.  These are the pilots' seats and fire extinguishers that will be in the cabin and cockpit.  There will also be various bags, ammo cans, and a couple M14s in the back.
Next up is to start detailing the cockpit.
    May 2009
Posted by Pawel on Monday, August 30, 2021 3:10 AM
Hello Gino!
Lookin' good - I like the work you've done on the the cockpit and the cabin a lot. Lookin forward to see it painted. Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
Posted by HeavyArty on Monday, August 30, 2021 10:23 AM
Thanks Pawel.
Posted by HeavyArty on Monday, September 13, 2021 9:02 PM
I have gotten quite a bit of work don​​​​​​​e it it the last couple of weeks.
I completed the rear cabin by adding a couple first aid bags, fire extinguishers, a rucksack, a duffle bag, an M14, and a few 7.62mm ammo cans for the M60A door gun.  I also washed it with a dirty grey-brown to make it looks a little lived in.  Lastly, I added some bare metal on the floor as well.
9a8271bcc4fa1b7178609041a8536487f9715173
1ed33cbf6e4f139eac91d9cd043abcc0e44ee090
Here is the IP and overhead console.  They are painted by hand and I used the kit instrument decals on them, and a few from the spares bin.3cab81b9bb9bed01d023791b6525d10361a299f0
The rest of the cockpit.  I added the fire extinguisher, placards and  other details.  I haven't added the seatbelts as I think I will put a couple pilots in it.
29f4225f886ebea7f732f9ad8d84b7c9394da3ae
e806cef412cbb30437533bb1b65b8d07b3b129e8
I have sealed up the fuselage as well.  I didn't really have any issues with the fuselage going together.  I did sand a couple spots that were sticking out and binding, but after that, there were no other issues.  It will require a bit of filler where the bottom meets the sides, but it isn't too bad.
f7f002d9713ccdc94a0c4e41b595be2a5c04f7ee
509fd9d081dfd67454cb894e166ce452f4c3d066
aaba4dc731c1a202c131c7e053e8133f476c0d48
0842d8c6f6be9c56c1dbbb5fc0ffcf386fa6af9f
It is finally starting to look like an UH-34D.  I am very pleased with it so far.  Next up is painting the inside of the nose, building the intake vents on the underside front, and installing the nose.
Posted by HeavyArty on Sunday, September 19, 2021 8:25 PM
More progress this last week.
I painted the rear side of the engine fan and drive shaft. I also added a couple hydraulic lines. Most of this will not be seen once it is all together.
IMG_1808
IMG_1809
I also added the screen and oil cooler on the underside.
IMG_1807
Once all that was done, I added the nose to the fuselage. I had no real issues with it, just a little bit of filling and sanding needed to blend it all together.
IMG_1812
IMG_1810
IMG_1813
The underside.
IMG_1811
Next is adding all the exterior details, tail, rotors, glass, etc…
Posted by HeavyArty on Sunday, October 3, 2021 2:47 PM
I have basically finished construction on the fuselage and the main parts of the helo.
I added piping and some other details found on H-34s (white styrene). I also added the teardrop-shaped antennas on both sides with small marker lights left over from another helo. The exhaust deflector below the port side front canopy is styrene as well.
IMG_1816
IMG_1817
The struts and tail wheel gear are 3D printed parts from Heli-Scale Quality out of Germany. I will also be using their decals later on as well.
IMG_1819
I added “C” channel (upper) and 45 degree angle (lower) styrene for the side door guides. The kit came with PE for this, but it was really small and almost impossible to fold and keep from kinking. I added the frames on the screens using thin wine bottle foil. I simply cut thin strips and glued them into place.
IMG_1814
I also plumbed the brake lines and rescue hoist. I cut half circle steps in each side and two new fuel filler points on the starboard side.
IMG_1818
I also had to modify the sliding door. On US H-34s, the window was centered on the side door. On the British Wessex, the window was further aft. I cut a piece out forward are of the window opening, then inverted it and placed it in the aft section of the opening and filled/filed it smooth. Door window successfully moved forward/centered.
IMG_1820
Painting is up next. I also have to build the main and tail rotors, which are kits in themselves with lots of resin, PE, and plastic parts.
Posted by keavdog on Sunday, October 3, 2021 3:34 PM
Very nice work.  Big fan of the Choctaw.
Thanks,
John
Posted by HeavyArty on Monday, October 4, 2021 6:58 AM
Thanks keavdog. I am really enjoying this build.
Posted by HeavyArty on Tuesday, October 5, 2021 8:16 PM
I was able to get the initial base coat of Medium Green on it. The USMC did not use Olive Drab as the Army did at the time. The 3D printed parts (landing gear and nose) look to have really blended together seamlessly with the plastic kit parts. I am very happy with how it is turning out.
IMG_1826
IMG_1822
IMG_1823
IMG_1825
IMG_1824
Next up is detail painting and the decals. They will be in a couple weeks though as I will be out of town for the rest of this week and next.
    September 2012
Posted by GMorrison on Wednesday, October 6, 2021 12:00 AM
Quite a nice project. The Wessex in itself is a really wonderful helicopter. That model OOB would be swell also.
One interesting thing is that the turboshaft engine (s) in the Wessex weigh considerably less than the big radial in the Chocktaw. I don't remember the engineering solution but it was considerable.
Thank you and your family for your service to this country. It must take a considerable leap of faith for a military family to send a young one out to serve.
Married?
Get out the checkbook. Get a lot of pictures.
Bill
Posted by HeavyArty on Wednesday, October 6, 2021 7:19 AM
Thanks Bill. The Wessex does look good, but I wanted a US H-34 so I could do it up as a USMC Vietnam bird. Military service seems to be a tradition in my family, she is just the nest generation carrying it forward. We are very proud of her.
