I used both an Aztek and then a Badger 175 through my Testors Blue Ice compressor... didn't have a prob.
make sure the air hose is screwed into the nipple well, it has a habit of loosening and you really dont hear all the air escaping with the noise of the compressor...
----edit---
oh yeah! I had this happen once, might have turned the nipple when putting the hose on the compressor, ends up I didnt get enough air. If you look through the body you can make out a rubber hose attaching the nipple assembly to the air source, make SURE this is not twisted, it would be the same as putting a kink in a water hose. the nipple assembly should turn so you can untwist it...
