Ch 53 Super Stallion Questions
Posted by Anonymous on Monday, December 27, 2004 12:19 PM
I'm working on a Super Jolly Green Giant/Super Stallion conversion. I don't know much about either (recieved it as a gift awhile back), and can't find a few things that I need. One, with ramp mounted 50 Cal. on the Marines Stallion, in pictures I see there are still the wheel ramps to allow vehicles on and off, Is the 50 Cal. removed before vehicle transportation, or is there another way to load the vehicle up without losing the 50 Cal., or when the 50 Cal. is attached, are vehicles only transported by hoist, or not at all? Two, are there any noticable changes in the engine that I should make? Three, there are few pictures of the area just behind and of the rear portion of the engine, and of the right side door when opened, any help with those would be appreciated.
Thanks in advance.
Chris Atler
    July 2003
Posted by ridleusmc on Monday, December 27, 2004 2:39 PM
Chris,
.50 cal mounts are not used on the ramp when CH-53E's transport vehicles internally. The CH-53E can carry 2 of the Marine Corps new recon vehicles (made by Mercedes) internally. I forget what those things are called, but they look like extended jeep wranglers. 53's also carry all sorts of aircraft Ground Support Equipment (aircraft tugs, Electrical Power Plants, Hydraulic power units, etc) internally. Many Marine Recon units use Yamaha dirt bikes which fit very easily. Humvee's, M198 howitzers, and even Paranah Light Armored Vehicles (LAV's) can be carried externally.
All this information applies to Marine Corps CH-53E's. I don't know very much about the other 53 variants.
Posted by Anonymous on Monday, December 27, 2004 3:19 PM
Chris,
Just as Ridle mentioned, I've only seen the Ramp mounted .50 Cal (M3M) when transporting troops or other cargo besides wheeled vehicles.
As for engine mods...not sure what you're asking. The H-53 uses the T64-GE series engine. Not very much difference from the 53D-53E.
    January 2003
Posted by yardbird78 on Tuesday, December 28, 2004 7:50 PM
One thing to keep in mind. The CH and HH-53, models A, B,C and D are totally different birds than the 3 engined E model used by the Marines. It looks very similar, but is actually a much larger machine. The obvious external differences include: the third engine, the "turtle deck" tapering from the upper fuselage area by the rotor head almost to the tail, the vertical stab is canted to port about 10 degrees and the main rotor has 7 blades instead of 6 with a larger diameter. You cannot simply take, say an HH-53D, add a third engine and call it an E. Alien [alien]
The B-52 and me, we have grown old, gray and overweight together.
    February 2004
Posted by LemonJello on Wednesday, December 29, 2004 11:39 AM
And no one makes a 1/48 -53E do they? I've got the old Revell HH-53C sitting on my shelf waiting, though I think it may go the Pave Low route. From what I've been reading here at FSM it would take some major surgery to change a -53C to a USMC -53E.
Man, I really want one of these. Well, if the -47 hits the shelves, maybe I can hope that a -53E will make it someday (maybe after I've whittled down the stash a little more).
A day in the Corps is like a day on the farm; every meal is a banquet, every paycheck a fortune, every formation a parade... The Marine Corps is a department of the Navy? Yeah...The Men's Department.
Posted by Anonymous on Thursday, December 30, 2004 11:59 PM
Chris,
Just to clarify on engine mods...I was referring to the actual engine nacelles themselves for #1 and #3 on the Es, and #1 and #2 on the A-D series. #2 engine on the Echos is positioned right behing #1 on the port side.
    July 2003
Posted by ridleusmc on Saturday, January 1, 2005 12:05 PM
Nobody make a 1/48 scale kit, but Italeri made a 1/72 scale kit. Revell Germany later reboxed it with different decals. They're kinda hard to find, but I'm sure they're out there.
Both kits lack detail and have fit issues, and the italeri decals are inaccurate. They got the squadron designations wrong. The kit decals say HMM-464, which doesn't exist. However, there is an HMH-464, so a little surgery with an exacto knife can fix that. The main rotor head of both kits is down right sad. It's just too plain and basic. They could have done more, even for the small scale. The interiors and cockpits lack pretty bad too. They didn't make much of an effort to represent the cabin, and the cockpit doesn't even look like a 53 pit. Missile detectors which bulge out of the fuselage under the pilot/copilot escape hatches and before the folding tail section aren't even there. And neither is the Forward Looking Infra-Red (FLIR) ball.
Even with all of these problems these Italeri and Revell Germany kits are about the only kits out there of the CH-53E. Some patients, time, research and scratchbuilding could turn these kits into a good representation of the Marine Corp's "Big Iron." I only work on my CH-53E kit from time to time. I'm a 53E mechanic, so everything needs to be juuuust riiiiight.
    January 2003
Posted by yardbird78 on Saturday, January 1, 2005 1:45 PM
One thing to remember about these kits. They were originally produced over 10 years ago. They were pretty accurate at that time. The H-53, like most other military aircraft has undergone various modifications since then. Some of these are black box type things that are not visible on the outside. Other items like the FLIR ball, IR missile sensors, flare/chaff dispensers, etc are visible and should be added for realism on a modern day machine. Most magazine and book references are several years old also, so recent pictures would need to be obtained from some source. Alien [alien]
Posted by Anonymous on Saturday, January 1, 2005 9:10 PM
Seems to be coming along nicely now. The kit really isn't good, alot of doctoring is needed. Alot of practice!
Thanks for the help everyone,
Chris Atler.
    February 2004
Posted by LemonJello on Sunday, January 2, 2005 9:07 AM
Revell of Germany has a 1/48 -53, I believe they call it a 53G/S. Anybody know how close to an E model that would be? I almost pulled the trigger on buying one yesterday, but then I thought I'd hold off and do a little more searching.
Posted by HeavyArty on Sunday, January 2, 2005 9:13 AM
The Revell CH-53G/S is the German designation for the US C/D models. Not an E model, above are the diferences.
    February 2004
Posted by LemonJello on Sunday, January 2, 2005 2:22 PM
Well, that answers that question pretty easily. I think I'll pass, as I've got plenty of stuff already in the stash to build before I worry about trying to modify a D to correct E stats.
Posted by Anonymous on Sunday, January 23, 2005 12:25 AM
In reference to a couple of things, the mercedes benz vehicles my bros in the corps use are called IFAVs (Improved Fast Attack Vehicles) The 53Es I rode on during my four years usually had the 50 cals mounted in the windows, and the occasional Mark 19 mounted on the ramp, dont ask me why, but I saw a few in Iraq set up the same way. Yes, the D and E mods are totally different on the top end, 3 turbines compared to 2 on the d, larger rotor head, and one more rotor just to name a few differences. Also, the D usually had larger blister packs on the side, compared to the e and usually wasnt outfitted with drop tanks the way the e models are. Check out the Navys version that they use for minesweeping (its a D model) to get a better idea.
Mem0ryLeak2005
Cpl, Inactive Reserve
USMC
0621/ 0656
3rd Bn 2nd Marines
Task Force Tarawa
    July 2003
Posted by ridleusmc on Sunday, January 23, 2005 7:36 AM
oh man it's 3/2, hide the beer.
Posted by Anonymous on Sunday, January 23, 2005 2:41 PM
Yup, hide the beer, Im a member of Alcoholics and Criminals anonomous, AKA the Betio Bastards lol.
Mem
What unit r u with
Posted by Anonymous on Sunday, January 23, 2005 6:13 PM
The Navy's current MCM platform is a MH-53E. The retired the RH-53s (Ds) a while ago.
