Wire/Cable Cutters on helicopters?
Posted by Anonymous on Wednesday, January 19, 2005 6:30 PM
I'm not sure i'm familiar with the concept of having those cable cutters on military helos. are they really used for cutting cables? seems to me the rotor would get the cable before the cable cutter does!Evil [}:)]
    January 2004
Posted by Mogwa on Wednesday, January 19, 2005 6:37 PM
Yes they are used to cut power lines. When I had the "opportunity" to use them in a UH-60 the lines were spotted just before the wirestrike and we entered a nose high climb to avoid the wires which allowed th wires to clear the rotor. Anyway since these wires are stronger then you think, its better to cut them then to snag and cartwheel the aircraft or remove an aircraft part that you would rather keep.
HTH,
Mog
UH-60 Crewchief / Technical Inspector and Modelling Addict
  • From: Modeling anything with "MARINES" on the side.
Posted by AH1Wsnake on Wednesday, January 19, 2005 7:35 PM
Yes, wires tend to be a nasty hazard when you're cruising through unfamiliar enemy territiory at 50-100 feet. Good idea to cut them rather than wrap yourself up in them!
"There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion."
  • From: Aaaaah.... Alpha Apaches... A beautiful thing!
Posted by Cobrahistorian on Thursday, January 20, 2005 12:23 AM
Jay,
Its more a protective measure than an intentional one. Hitting a high tension wire at that speed doesn't bode well. The strike kits help somewhat in avoiding that.
"1-6 is in hot"
Posted by Cobrahistorian on Thursday, January 20, 2005 12:24 AM
Hey Snake,
Which markings are you putting your Whiskey NTS in?
"1-6 is in hot"
Posted by upnorth on Thursday, January 20, 2005 5:06 AM
I remember the Kiowas that 408 Squadron at CFB Edmonton used to fly, not only did they have the cutter devices, but the piece of framing that ran up the middle of the windshield had a saw edge all along it to help cut the wire.
Posted by Anonymous on Thursday, January 20, 2005 8:25 PM
ah.... i didn't realize that the possibility of running into power lines was so high.
Posted by grandadjohn on Thursday, January 20, 2005 8:29 PM
Yea, they are high when you're flying low
