mjohnson,
Helos are a tough choice because there aren't as many out there and some of them
stink. Many guys rave about the revell stuff in 1/32 but they're big...I'd avoid the Italeri
stuff in 1/48 because the ones i've done aren't very detailed and do not fit well. I'd try
any of the new stuff by academy/mrc...the problem is most of them are in 1/35. 1/72 will
be very small unless you're modeling a chinock or a sea king...something larger in
real life.
Panda makes a couple of great looking hueys 1/35 in the box with seemly nice details...
however they're not worth the price and many have problematic decals which are tough
to apply. In addition many important pieces fit poorly.
You might try an apache by academy of korea it will cost you about $20 and in comes
in 1/48...I think they might also make a blackhawk or pavehawk as well in the same
scale. These are the older ones but fit better and are easier to handle then some others.
I'd recommend you go with a quality manufacturer on your first one out...Avoid the
cheaper models which lack detail and good fit...avoid the huey UH1D by italeri in 1/48..
just built it ans was disapointed...Avoid Revell's huey hog...it lacks much and fits worse..
Unfortunately your best bets are in academy's newer kits...those are among the next
ones i'll buy...
Good luck
Tank
