AH-6J After-Market Ammo Belt Question
    February 2004
Posted by Trigger on Monday, March 21, 2005 9:02 AM
For those of you familiar with the Cobra Comapny ammo belt... I got a couple of pair I recently; can I use a set to replace the original DML ammo belt from the AH-6J kit? Would the new belts be accurate?
Thanks in advance
------------------------------------------------------------------ - Grant "Can't let that nest in there..."
Posted by HeavyArty on Monday, March 21, 2005 9:56 AM
Yup, the CC belts are the same, standard type of flexible metal belt that the 7.62 ammo belts travel inside. They are correct for an AH-6J.
    February 2004
Posted by Trigger on Monday, March 21, 2005 10:01 AM
Cool. I thought as much, but it's still good to double check. Thanks for your help Gino.
Posted by Anonymous on Monday, March 21, 2005 11:05 PM
hi what brand is the AH-6
Posted by HeavyArty on Monday, March 21, 2005 11:11 PM
1/35th DML/Dragon AH-6J LIttlebird. Great kit.
  • From: Modeling anything with "MARINES" on the side.
Posted by AH1Wsnake on Tuesday, March 22, 2005 12:34 AM
Grab 'em while you can.....I remember the posts on this forum when the kit was unavailable, and everyone was going through withdrawl! Got mine sitting safely on the shelf now Tongue [:P].
"There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion."
    June 2003
Posted by cameraflage on Friday, March 25, 2005 12:26 AM
I'm in the process of building both an MH-6 and an AH-6. I had many naughty words directed at DML for providing straight ammo belts that needed to be bent to reach the guns. I screwed up all four of the belts. Then I started rummaging through my various boxes of odds and ends and came up with a length of Tamiya M-3 halftrack track. I split the track down the middle and trimmed the edges smooth. Its flexible, serrated and just about the right width (although its a lot thicker than the ammo belt probably should be).
I fitted the guns tonight, and the belts look pretty good. I could have sprung for the Cobra belts, but hey, I'm cheap (although I did order the MELB kit from Cobra for the MH-6, per your suggestion, Grant....thanks mucho again for the help.)
Ranger Joe, Defender of Bunnies "Feed the rangers, not the bears" www.nls.net/mp/cameraflage
    February 2004
Posted by Trigger on Friday, March 25, 2005 3:26 AM
No problem Joe. I picked up the ammo belts seperately from Cobra and they weren't at all expensive. I'm using the MELB conversion on my AH-6 as well, just not using the running boards. It's a great set and looks fantastic. With any luck I'll have pix up of my first Little Bird over on the Attack Helo GB thread by weekend's end.
Posted by HeavyArty on Friday, March 25, 2005 10:14 AM
Great idea for ammo belts. I have an old halftrack that could donate some ammo belts too. Sounds good.
    June 2003
Posted by cameraflage on Friday, March 25, 2005 6:37 PM
I looked at Cobra's website today and didnt see any ammo belts like you mentioned....are they a separate item or part of a set? I saw an ammo belt included with the M-230 gun set for a Blackhawk but I dont think this is what you meant ( it also appeared to be a straight length of polyurethane resin, which would crack faster than the four styrene ammo belts included with the Little Bird kit...in my case, eight short ammo belts.)
Posted by HeavyArty on Friday, March 25, 2005 6:41 PM
They are part of the UH-1N Weapons set. Chris will sell them as separate items though. They, and those in the M230 cannon rig set, are soft rubber, not resin.
UH-1N Weapons set.
