Realistic Drooping rotors- how to?
    September 2003
Posted by blkhwkmatt on Wednesday, April 6, 2005 4:12 PM
Does anyone here know of a method to realistically droop the rotors on a helo. I am working on 2 blackhawks and want to have the rotors droop and if possible have the twist to them as well. Any help would be greatly appreciated.
Thanks
Quidquid latine dictum sit, altum videtur!!! - Anything said in Latin sounds profound!
  • From: Modeling anything with "MARINES" on the side.
Posted by AH1Wsnake on Wednesday, April 6, 2005 4:34 PM
Try getting a basin full of hot water (not hot enough to make your hands uncomfortable), then take your blades under the water and gently bend them a few degrees. The warm water should soften them up enough to make the blades pliable. I have also heard of running a warm hairdryer over the plastic to make it bendable (keep it at a distance so they don't melt!). As always, be careful not to break the blade, and don't give it too much droop! That's hard to fix. Just do a little bit at first, and if you decide that it needs more, you can always go back and do it again.
"There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion."
    September 2003
Posted by blkhwkmatt on Thursday, April 7, 2005 3:56 AM
AH1WSnake - thanks for the tips I think that i'll try the hot water one first as it seems the more conservative method. I was thinking about making a jig of sorts to hold the blade in to get the right twist and droop, and that would work with the water method fairly well.
Posted by Anonymous on Thursday, April 7, 2005 1:22 PM
Dang! I wish I had seen this topic, I just painted my Huey Hog's rotors!Blush [:I]
