I can second that. I'll add that due to wear, tear, oil and exhaust the paint will slightly darken over time. It seems that areas forward of the engines tend to be lighter than areas aft of them. Touch up paint and is often much lighter than the rest of the aircraft. 6 months working Corrosion Control taught me that. Let me see what pics I can find to give you an idea of what I'm talking about.
These pics should give you a good idea about weathering. Unfortunately I don't have a good 46 pic at the moment, but they're cleaner birds than 53's and Skids because their exhaust are at the rear of the aircraft. They usually have a band of soot around that starts at the exhaust and goes back and down at about 45 degrees to the ramp door area.
