- Member since
Posted by albymoore
on Friday, May 20, 2005 3:14 PM
QUOTE: Originally posted by grandadjohn
Mongram' is better
Ditto, Grandad John is correct. If you want a really good OOB AH-1F/S, then Monogram is the way to go. The cockpit is really nice, with raised details for easy painting. The only thing it could use is some details on the back wall and the HSS rails and wiring on the canopy. The fuselage is right on the money in terms of dimension and shape. It is a bit of a bear to build, but nothing a little patience and time can't overcome. For a late F model Cobra, you'll need to add the inlet flow diverters and a M130 Chaff/Flare dispenser to the tail boom, just below the vertical fin.
HTH,
"I know what it wants now...the void has swallowed the light and the machine wants my soul"
