Greetings FITTER & Papa-Echo and all,
Here's a link to the main framed site where you can have a menu on the right to surf through, instead of hitting each page.
http://modeling.gunsagogo.org
I tell you waht, PE, if I had gotten to the point you have with your Chinook, I'd probably be out there working on it right now instead of in here typing on the computer!
Your exterior, rotorheads and control closet are looking good!
Since modifying that Chinook, I've done some experimenting with imitating the interior sound proofing texture by making aluminum foil "sections", and pressing the foil against a positive cast mold that I made using the aft molded insulation section of a Monogram 1/48 UH-1C. Of course the seat canvas is on that particular piece, but as I said, it was an experiment to see how it would come out.
After pressing foil onto the positve mold, the exact pattern was transferred to the foil, and when painted/dry brushed, it was remarkably life like!
The next time I start loosing my marbles
and decide to re-build an Aurora Chinook, this technique could be a great way to duplicate interior sound proofing, with a little refining.
(I also wished that I would have removed the upper 1/3rd of the left side fuselage, and replaced it with a pre-shaped clear piece, so all the detailing could at least be a little visible)
In the meantime, Happy Modeling!
