QUOTE: Originally posted by RotorRob60
Feel free to ask for whatever info you may need regarding the UH60.
Wellcome!
I have couple of questions if you don't mind
#1 HOIST
"...324 had a hoist mount, but no hoist was installed. It would be a U shaped piece of metal about a foot long and about a foot forward of the right hand engine air inlet..."
The problem is that I have no idea how the mount looks like at the end where it suppose to connect to hoist... I suspect there are some wires or holes but picture or little explanation might help.
#2 HUD
"...324 had a HUD (heads up display) for the right side pilot. It was about 11 inches long, by about two inches square. The pilot could look through it for weapons sighting, although it wasn't used much..."
I found only one pic of the hud in the manual:
but it doesn't show where the exact mount place is and how the HUD looks like in OFF position... I mean it probably can be moved or turned away somewhere not to block the pilot's view when its not in use...
Thanks
Andy
P.S. this is for my MH-60L
