Has anyone else had fit problems with this kit? I am test fitting the two fuselage halves and I have large gaps between the cockpit bulkhead (the piece the seats attach to) and the fuselage frame. What do you recommend to correct this problem?
Also, does anyone have a good picture of the mini gun from the rear? Either the real aircraft or of the kit. The directions are not clear to me as to where a couple of the peices are actually supposed to attach.
Thanks.
