QUOTE: Originally posted by tomcraft66
Yeah thought as much, most I can recreate with solder and styrene section.
Creative gizmology - never heard it called that before! Most pipework and features on the engine I can figure out how to recreate, but there are a number of large diameter (2-3" full scale) braided hoses which would be good to recreate if possible. They may be harder to do, but ultimately simplified if it is to difficult to recreate the braided finish.
1/24? Crikey, that's a big kit!
The larger braided lines (ie. the fuel lines) *might* be recreated by covering a core of something (solder, wire, whatever) with the outer sheathing from parachute cord. Its braided and I betcha if you gutted it (yanked out the seven fibers running thru the middle) and painted it a bright silver it might look like those Aeroquip-style braided stainless lines. Then again, it may be out of scale. Not 100% sure.
That's just a guess. I haven't tried this yet, but that's one of the "back of my head" ideas for simulating external load slings when I get around to building that 1/35 'Hook hovering over a Milvan or Hummvee.
I'm not sure if you can find regular military-style para cord ("550 cord") smaller than the "usual" 4mm diameter, but I do know that civilian skydiving gear doesn't use that bulky stuff anymore in favor of newer technology braided lines made out of high-tech blends of kevlar, dacron, nylon and other materials. You might be able to obtain a short length of the smaller diameter from a local dropzone's rigger shop, although much of the newer material isn't tubular, its flat.
EDIT: here's some closeups of 4mm paracord: http://www.vtarmynavy.com/parachute_cord.htm
and 2mm+ "accessory cord"
http://www.info-central.org/recovery_cordinfo.shtml
Darin
CH-47C, 67-18500
Korea, '86-'89
Darin Ninness
213th Avn Co, ROK 86-89
CH-47C, 67-18500 "The Pride of Texas"
