AH-1G HueyCobra 1/32
    December 2004
Posted by Hippy-Ed on Monday, November 7, 2005 12:05 AM
Hey fellas, I thought I'd run this kit by y'all to see what I got & if it's worth putting together. It's a Revell Kit # H-287 1/32 HueyCobra (dated 1967 by Revell Inc., Venice,Calif) I recently found this while cleaning out a guy's backyard! He gave it to me & it's complete. Someone had painted the engine but, near as I can tell, it's all there & in good shape. Any good???
If you lose your sense of humor, you've lost everything
Posted by HeavyArty on Monday, November 7, 2005 12:12 AM
It is a pretty good kit, especially for its age. They just recently re-issued it, witha couple of upgraded piecses and new decal options. The old one will still build up nicely though. If you ant to putt some extra work into it, Cobra Company does a replecement cockpit adnd a couple of other sets for it in resin too.
CC Site: http://www.cobracompany.com/32nd_scale_models.htm
Fierball Modelworks also has an upgrade set and other decals for it too.
Fireball Modelworks site: http://www.fireballmodels.info/
Definitely a keeper, good find.
    December 2004
Posted by Hippy-Ed on Monday, November 7, 2005 12:36 AM
Thanks for the input & the linksTongue [:P] I'll check them out & although I'm not much of a chopper guy I might just build this up when I need a break from my planes[:0] Keep the razors sharp!!Propeller [8-]
  • From: Aaaaah.... Alpha Apaches... A beautiful thing!
Posted by Cobrahistorian on Monday, November 7, 2005 12:45 AM
Ed,
Definitely a good kit, and like Gino said, with some extras, it becomes world class! Plenty of markings options out there as well. I definitely recommend it!
"1-6 is in hot"
    December 2004
Posted by Hippy-Ed on Monday, November 7, 2005 12:54 AM
QUOTE: Originally posted by Cobrahistorian
Ed,
Kewl! Thanks for the info. Just outta curiousity, what would this kit run nowa days if I were to sell it?
Posted by Cobrahistorian on Monday, November 7, 2005 12:59 AM
Ed,
Tough to say. They just reissued it recently. I've paid about $20 for an original issue one, but they're pretty common on ebay.
"1-6 is in hot"
    December 2004
Posted by Hippy-Ed on Monday, November 7, 2005 1:09 AM
Ok thanks, I was just curious since I didn't know if it was a common kit or not.
Keep the razors sharp!Propeller [8-]
Eddie
    March 2004
Posted by MBT70 on Monday, November 7, 2005 10:19 AM
I built that kit a couple times over the years and both times the tail fin had a bad twist in it on both sides of the fuselage halves. The wierd thing was that they fit together perfectly, even with the twist, so I didn't realize it was wrong the first time. I think it came from sitting in the box in theheat or something like that, but watch for it in your model. Otherwise ... it's a very neat kit, especially for it's day. I hand-painted a big sharkmouth on the last one and a Cobra pilot bought it from me for $150.00 he liked it so much.
Life is tough. Then you die.
Posted by HeavyArty on Monday, November 7, 2005 10:44 AM
QUOTE: I built that kit a couple times over the years and both times the tail fin had a bad twist in it on both sides of the fuselage halves. The wierd thing was that they fit together perfectly, even with the twist, so I didn't realize it was wrong the first time.
The curved tail is correct for a G model. Nothing wrong with that part of the kit. It is supposed to be there.
    June 2003
Posted by supercobra on Monday, November 7, 2005 11:00 AM
MBT70 is a Vietnam "Snake Driver" - I'm sure he knows what is correct. He was proably talking about a twist beyond normal.
Randy
    March 2004
Posted by MBT70 on Tuesday, November 8, 2005 2:08 PM
The tail on a Cobra has an airfoil camber which augments the thrust of the tailrotor and helps establish more counter-torque authority.  The kits I had, and this was over 20 years ago, were definitley distorted beyond the normal camber.  The early Cobras had the tailrotor mounted to the left which, it was soon discovered, tended to mask part of the thrust it generated and degraded it's effectiveness, so all the aircraft were retrofitted with a right-mounted "tractor" tailrotor that corrected the error.  I noticed that one supplier ... I think it's called the CobraShop or something like that ... sells a replacement tail fin for the 1/32 kit with the tractor rotor feature.
Posted by HeavyArty on Tuesday, November 8, 2005 5:32 PM
No offense ment above, just clarifying and didn't know you were a former Snake Driver.  It is actually Fireball Modelworks that makes the new tail section, along with the toiletbowl exhaust and intake separators as part of their Anti-Strella kit.
http://bellsouthpwp.net/o/s/osborn82/fm32_001.htm
    March 2004
Posted by MBT70 on Wednesday, November 9, 2005 5:34 PM
A couple clarifications ... I found the aforementioned parts by clicking a link posted on "The Cobra Company" website ... which took me to Fireball Modelworks ... so you are correct and that is indeed where I saw the part.
The other thing ... I wrote a book called "Snake Driver! Cobras in Vietnam" (Random House - 1993), but was not a Cobra Pilot myself.  I was, at different times, crew chief and/or door gunner on Hueys, OH-6 and Chinooks, and an Armor Crewman, Flight Operations NCO, Match Team Rifleman, Illustrator and Army Journalist.
You can squeeze a lot of  adventure into 24 years of Army.
    December 2004
Posted by Hippy-Ed on Friday, November 11, 2005 10:38 AM
I salute y'all this Veterans Day. I didn't realize there were so many vets, former Snake Drivers/fixers,etc.
Thanks for the input on this kit and, your own recollections of the real mccoy. Gives one alot to consider before building.
    July 2004
Posted by stikpusher on Wednesday, November 23, 2005 7:28 AM
I built the new re-issue of this old gem a few months ago. It went together pretty well, the new parts really dress up the armament, and the decals were excellent. Yes it cost many times more than the original issue ever did, but it's still worth it. The mold show their age on the chin minigun's detail, but overall I would reccomend it to Cobra fans. Probably do another one with a Cobra Company detail set once I get home just to see what I can realy do with this kit.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    December 2004
Posted by Hippy-Ed on Wednesday, November 23, 2005 10:19 AM
thanks for the heads up on this stikpusher. I've gotthe cobra set on my Christmas list.
    July 2004
Posted by stikpusher on Thursday, June 8, 2006 2:16 PM
Okay folks, here is the finished kit. please keep in mind this was built while I was on Deployment in the Balkans with a very basic paint set, hand brushed, and minimal tools. It currently resides at the coffee shop next to the flightline on the base I was deployed to.
       - Plankton
LSM
    December 2004
Posted by Hippy-Ed on Friday, June 9, 2006 3:57 AM
Looks sharpBig Smile [:D] Thanks for posting this
    March 2004
Posted by MBT70 on Friday, June 9, 2006 9:10 AM
Good job, especially for a field build!  And I see the tail doesn't have the twist mine suffered from.  One question ... did that intake grille come with the kit?  The original kit didn't have any and I made mine by bending a piece of wire to fit the opening and covering it with brass mess from a fuel filter.  The one in the photo is really crude and doesn't deserve to be on your fine model.  The actual item was a mesh basket that clipped on over the intake and kept out larger particulate like leaves and sticks.
    July 2004
Posted by stikpusher on Friday, June 9, 2006 4:21 PM
Thank you! This kit was built straight out of the box. A new sprue was included in the most recent release which had the new rocket pods, new stub wings, the grills over the intake, and the rotator beacon behind the main rotor. I now want to build another with some Cobra Company aftermarket stuff and tricks of my own now that I have my all home stuff again...Wink [;)]
       - Plankton
LSM
Posted by grandadjohn on Saturday, June 10, 2006 11:57 AM
Not a bad kit for it's day, built it and the UH-1D from Revell back in 1971 right after I left active duty, with today's Am stuff, can be really improved on
    July 2004
Posted by stikpusher on Tuesday, June 13, 2006 12:04 PM
Yes I picked up the combo kit of the UH-1D/OH-6A and have it in my stash of to do's. First I need Dragon to reissue their chopper crew set so I can get some M-60Ds and the gunners...
       - Plankton
LSM
Posted by Anonymous on Tuesday, June 13, 2006 2:14 PM
I picked up the newer kit at a Ross retail store for 8 dollars.  I was amazed that they would even have it there.
Posted by Melgyver on Tuesday, June 13, 2006 9:36 PM
It's hard to believe the first helicopter designed and built as a gunship and no "new" kit of the AH-1G Cobra has been produced.  The Cobra and Huey, the two most utilized helicopters in Vietnam and many conflicts since have yet to given the honor and respect they deserve in a new detailed 1/35 or 1/32 kits!  It's a sacrilege to all the aircrews who sacrificed their lives in these proud birds serving our country!  Academy/MRC you need to step and do the "right" thing!  Make a AH-1G and UH-1D/H!
Clear Left!
Mel
Posted by Cobrahistorian on Tuesday, June 13, 2006 10:29 PM
AMEN to that!
"1-6 is in hot"
Posted by grandadjohn on Wednesday, June 14, 2006 9:59 AM
I am in 100% agreement with Jon and Mel
Member #005
DAVID VOSS
Anti-defamation
League
Posted by midnightprowler on Thursday, June 15, 2006 12:18 PM
I couldnt agree more!
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
  • From: Modeling anything with "MARINES" on the side.
Posted by AH1Wsnake on Thursday, June 15, 2006 2:13 PM
Preach on, brothers.
"There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion."
