UH-1C transmission again
    November 2013
Posted by intruder_bass on Friday, February 10, 2006 10:18 PM
While waiting aftermarket parts for my new Super Cobra to arrive, decided to continue building my C Huey. Here is the last pic of transmission and engine compartments.
 The questions are:
1.I remember you guys told me there should be anti-skid surface on top of the fuel tank - I even recall word - "maintenance deck" ))  So how this surface looks like? rough stripes? mesh-type or something else?
2. What is under the transmission module mount, in the middle of the floor? Is there some kind of hole for the mast and for the lower part #17 (pipe #) 20   on the pic
Any pic of this area?
3. Any PHOTO of area where the hydrolic lines should be on the front wall of this compartment?
What about the rear wall? Even free hand drawing or other scheme will be helpfull!
Thanks a lot
Andy
Posted by grandadjohn on Saturday, February 11, 2006 2:17 PM
1. The flooring is stainless steel plating(if I remember right) with a diamond pateran(sp)
2. The hole below the transmission is the "hell hole" and filled with all kinds of things such as flight controls, plumbing, cargo hook, if installed
That's all I can remember right now. I have no photo's of that area, nor do I of the bulkhead in front of the transmission. See if you can find the TM(-20) for the HUEY, would be your best bet.
Posted by Melgyver on Sunday, February 12, 2006 12:59 PM
Andy,
You are doing a fine job there!  Something I've always wanted to do, but haven't as yet.  If you can wait a couple days I'll try and get some pictures I have taken of a "Mike" model that was on display some years ago.  All the cowling was off, engine missing but the transmission and all the hydraulic pumbing was still there.  The "pipe" #20 is actually an transmission oil line I would suspect with the breakaway fitting represented .  There is a retangular hole under the square transmission support that was called the "hell hole" for reasons apparent when attempting to work on any lines or hydraulic servos.  This is directly over the area where the cargo hook is.  The hook is acutally hanging by a link to a main beam on "Hotel" models.  I didn't crawl under the "Mike" model to visit the "hell hole".  The model has a cargo hook glued to a recessed pan.  Not correct.  Back to the tranny deck.  Lots of plumbing and two hydraulic reservoirs  on fwd bulkhead, area #3 and the engine oil reservoir against the aft bulkhead.   Just about where you have the #1 is an inverted bowl covering access to the Fuel pump .  A braided fuel line exits the 5 o'clock of the bowl and goes to the aft inside corner of fuel cell.  I'll do my best get the pictures either copied with my digital camera and E-mail them or attempt to install a new scanner I got for Christmas.  Not a computer guru and hate messing with new "stuff"!   Keep up the great work!
Clear Left!
Mel
Clear Left!
Mel
    November 2013
Posted by intruder_bass on Sunday, February 12, 2006 6:23 PM
Thanks for explanations guys...
Mel,
sure I'll wait for the pics! Take your time. There is no rush at all. I just wanna do everything right there on my model.
grandadjohn,
If I uderstand you right this diamond pattern steel plate looks like this?
http://www.haartz.com/news/20021025/diamondplate.jpg
What color is it BTW? Is it painted or stays mettalic?
Andy
Posted by Melgyver on Sunday, February 12, 2006 9:28 PM
Andy,
No, it's not that pattern at all.  It's more like the pattern of the soundproofing blankets only with about 1/4 in. "diamonds".   It usually is the shiny stainless steel that is is made from.  It is the outter layer of the "honeycomb" panel.  It may show up in the pictures that I have.  I have one more day home then back to work for 7 days offshore.  I'll definitely get you something in a couple weeks at the longest.  I'll try and get you something tomorrow before I leave.  You may give me some inspiration to get back to work on mine.
When you do get the pictures you will notice the swashplate ears are different that the one in the kit.  It's actually for a "Bravo" model.  The rotating ring is slightly different in shape too.  Little things like that have kept me from finishing mine.  I kept finding more things to fix!   Ha, ha!
Clear Left!
Mel
Clear Left!
Mel
    November 2013
Posted by intruder_bass on Wednesday, February 15, 2006 8:43 PM
Guys,
I've got couple of great photos of transmission compartment from Mel recently. This is UH-1M (I am building C) but as far as I know - they where allmost same thing.  The question is about these green fuel pump covers on both sides of transmission mount. I was wondering - is it just an M mod feature or Charlies also had it? Anybody can confirm this?
Thanks
Posted by grandadjohn on Thursday, February 16, 2006 7:55 AM
The M model is an upgraded C model, it has the -13 engine otherwise no difference
Posted by Melgyver on Thursday, February 16, 2006 12:00 PM
John,
The pictures I sent Andy are of National Guard birds they were flying in the early 90's.  So it is possile the fuel pumps on the topsides are mod's after the early 70's.  That is why he is asking about it.  I'll have to try and see if any of our old Crew Chiefs in the Sharks remember the "toe catchers".
Clear Left!
Mel
Clear Left!
Mel
