'GUN' options on Vietnam Hooks?
Posted by Papa-Echo-64 on Monday, February 27, 2006 2:13 PM
Other than the GO GO Hooks....Did any other Hooks in Nam have ramp or more than one side window 50/60 Cal?
Straighten up and fly right.....
Posted by Melgyver on Monday, February 27, 2006 2:33 PM
Don't know off hand, I believe they usually had a crew of 5 leaving  three enlisted to man any guns on regular Hooks.  If anybody did it would have been the 101st.  They put guns on some of their Medevac's.  Both exceptions to the "rule"!
Clear Left!
Mel
Posted by Anonymous on Monday, February 27, 2006 4:06 PM
       I think I have some pictures someplace of some dustoff helos with a 60 on the door. .... Geneva convention?
Posted by grandadjohn on Monday, February 27, 2006 8:03 PM
The VC liked those big red and white targets on the sides of medivac's to some armed as self protection
    July 2003
Posted by oldhooker on Tuesday, February 28, 2006 11:44 AM
Troy,
    Here's a couple diograms from the Chinook TM showing the mounted gun positions on a Slick Chinook.     In Vietnam, it was also common to have the aft side window panels removed to allow cabin personnel a gun port for their personal weapons.
Hope this helps...
Take care,
Frank
Posted by Papa-Echo-64 on Tuesday, February 28, 2006 11:26 PM
Thanks Frank!
but.....did any other Hooks in Nam other than the Guns A Go Go have the 'ramp' mount armament?
    July 2003
Posted by oldhooker on Wednesday, March 1, 2006 12:14 AM
 Papa-Echo-64 wrote:
Thanks Frank!
Troy,
  Unless some unit rigged it's own mounting platform, the Go-Go's were the only ones with permanant fixtures attached to the ramp.    Slick units used the ramp for loading/unloading material & personnel, so having a non movable .50 mount would be impractical.
Take care,
Frank
Posted by Papa-Echo-64 on Wednesday, March 1, 2006 9:59 AM
Thanks Frank...I should have gave that some thought....a real no brainer
  My Cousin had a blast with those duel 50 Cal's on the nose of his MKII Pibber during the Brown water opps...."of course they never wher in laos" Whistling [:-^]
Wher those forward door and window gun mounts easily moved side to side on the support bars by just the gunners will alone or where the 'gun mounts' cable assisted via springs or something?.......and I take it that the M24 aircraft system is the basic M-60D?
    July 2003
Posted by oldhooker on Wednesday, March 1, 2006 7:21 PM
Were those forward door and window gun mounts easily moved side to side on the support bars by just the gunners will alone or where the 'gun mounts' cable assisted via springs or something?.......and I take it that the M24 aircraft system is the basic M-60D?
Of course... Whistling [:-^]
The crew removed the weapons at the end of the day, along with the ramp M-60D mount (if used).     The #2 position (CE Door) mount swung open via a hinge, and was locked in place by a pip pin, to allow crew access.     I don't remember if I ever saw the mount in the #1 Position opened.   (might have been, but I never saw it)
Here you can kinda see the CE Door mount.
Oh yeah....... in the picture I posted earlier of Go-Go ramp, note, there's no secondary ramp within the ramp body... the ACH-47's didn't use the secondary ramp because of internal bracing. FYI [;-)]
Take care,
Frank
Posted by Anonymous on Wednesday, March 1, 2006 11:35 PM
Hey Frank!!
Did you get the pix I sent you a few days ago of my projects for my Trump Hook??   What ya think??
Sence we are on the subject of the armament of the Hookers,I have a question.    Is it realilistic to put a gunner on the ramp holding a M60 ( the one that was carried in the troop platoons not the M60D used on Helos) with no ramp mount installed??    I konw that he is always strapped to the monkey harness becouse he might fall out during violent monuvers.Wink [;)]
Thanks Frank.
MarkSmile [:)]
Posted by Papa-Echo-64 on Thursday, March 2, 2006 8:48 AM
Thanks again Frank!
I guess what I meant to say was: Did the door and window 'Guns' easily move right to left on the round bars or where they spring or cable assisted?
Hey Mark...what pics....what gives? Smile [:)]
Posted by Anonymous on Thursday, March 2, 2006 9:18 AM
Pics?.. Pics that havent been shared with the group!? tisk tisk
    July 2003
Posted by oldhooker on Thursday, March 2, 2006 6:25 PM
 marke wrote:
Hey Frank!!
Thanks Frank.
MarkSmile [:)]
Hi Mark,
   Yes, I did get your email.  I apologize for not sending a comment right away, as I have been a bit busy.    You have the angles right on your gear struts it appears... can't wait to see you start putting them together.    Looking forward to seeing some construction pictures. Smile [:)]     Also, it wasn't all that uncommon for a crewmember to man a hand held M-60 on the ramp, but generally they were attached to the mount.     Also, concerning "violent maneuvers".... simply moving through unstable air, such as heat thermals or in gusty conditions, can render the crew member temporaily weightless, and bounce him right off the edge of the ramp.   (he's going to be grabbing for something to hold onto and turn loose of the weapon..... that's why mounting it was preferred) Wink [;)]
Hi Troy,
   For lack of a better picture, I am posting this one of a door gun mount in a CH-21, which affectively shows a similar type locking mechinism on the mount tube.       Hope this helps a little.
Take care,
Frank
Posted by Papa-Echo-64 on Thursday, March 2, 2006 8:41 PM
Thanks Frank... GOLLY! thats a very cool and helpfull pic.....its in my favs! Thumbs Up [tup]
Posted by Anonymous on Friday, March 3, 2006 12:00 PM
Hey guys.
If any of you are interested in seeing my pics of my projects for my Trump Hook,contact me at my email address and I will send them to you.
I've tryed and tryed to post them to the forum but can't get it to work.
Sorry.
Drop me a line!!Wink [;)]
MarkSmile [:)]
