EASY and CLEAN way to Mask Clear Parts!
Posted by Papa-Echo-64 on Friday, March 31, 2006 2:07 AM
This is the ONLY way I mask my canopies.....I just did this today on my 1/35 Chinook.
Clear shelf/contact paper....$5.99 to 7.00 bucks at your local Fred Meyer or Home furnishing shop.
Just cut a piece that is larger than the window section your masking and then using your finger nail, burnishing tool or what ever to snug the material down firmly in and againts the frame/recessed panel lines.......after that using a new number eleven blade start at a corner or mid section and carefully and with not so much pressure cut along the edges....Now keep in mind that you are keeping the window sections and removing the material exposing the frame work to be painted.....even if the material does not sit down 100% perfect you can still SEE where to cut as you go...then push down the material after you remove the unwanted sections.....next thing you know you are done!
I like to do this before adding the canopy to the model so I have more control of my work.
Paint the canopy or model.....then after the paint is dry.....use your number eleven blade to carefully lift one corner then use tweezers to lift up each section.
After a while you will get the hang of it......can anyone guess what 1/24 canopy I dug out of my parts box for the demo?
Straighten up and fly right.....
Posted by HeavyArty on Friday, March 31, 2006 9:07 AM
Yup, I use the same technique, but with masking tape.  Works great every time.
    August 2003
Posted by bilbirk on Friday, March 31, 2006 10:08 AM
what kind of masking tape do you use
Posted by HeavyArty on Friday, March 31, 2006 10:18 AM
Standard 3M brand tan masking tape.  Usually the 1" to 1 1/2" wide one, but it comes in all widths. I find that the 3M brand is the best, the other (cheaper) ones rip too easily or don't stick well.
    May 2015
Posted by willuride on Friday, March 31, 2006 10:35 AM
I do the same thing with the blue painting tape from wal-mart.  Low tack stuff, I love it.
On the bench Knoxville, TN:
1/48 Monogram F-4 Phantom "Black Bunny"  I wanted to relive the past....Never again
On the Bench Manchester, TN:
1/48 Revell F-18E
Posted by Papa-Echo-64 on Friday, March 31, 2006 10:55 AM
NICE PIN UP  Willuride! :-)
Yep.... I love the blue tape as well.....I use it for all other masking....but with this stuff you get a lot more for your buck, it's low tack and its clear so you can SEE what your doing.
Posted by Melgyver on Friday, March 31, 2006 7:05 PM
Good idea using the clear contact paper.  I had always used Scotch Tape.
Clear Left!
Mel
Posted by Anonymous on Friday, March 31, 2006 7:55 PM
I"ll have to hit the Freddys tonight. I usually use bare metal foil.
Posted by Papa-Echo-64 on Friday, March 31, 2006 9:34 PM
Hey Mel.....I think you will find this stuff a lot easier to remove than scotch tape....ouch!
Glad to help.
The next session will be on MAKING THE PERFECT PAINT CHIP effect.
......after I try it out on some test parts I have set up for my Hook.
What.....no guesses on what WWII aircraft the canopy is from???
its an easy one!
Posted by Anonymous on Saturday, April 1, 2006 12:01 AM
Well, that test canopy look to be a   me 109???
Sence we're on the subject of masking windows,  I've been hearing about useing Elmers white glue to do this.   Does this work well??  Seems to me it should becouse white glue doesn't usualy stay stuck to a slick surface like a clear canopy.
Mark
Posted by Papa-Echo-64 on Saturday, April 1, 2006 12:11 AM
ME 109-E
Mark wins a USED cat box and a picture of the cat that did it!
Mark....That technique and canopy masking products like that are ok.....but its hard to control, get into tight places, nice crisp straight lines and sometimes its impossible to remove...especially from recessed lines you did not know that where there untill its too late!
It took me five years to use up just one roll of the stuff and thats with my wife using it as well doing glass etching.....not bad for just 5.99!
Posted by Anonymous on Saturday, April 1, 2006 12:34 AM
YEE HAW!!!  I win!!!   Don't care for the prize though!!Tongue [:P]
As for as the white glue, I'll use that trick cousiously.   Scoch tape is easy to appy and cut out around fine detales BUT getting it off is a chore!!
I wonder how Glad cling wrap would do??  I'll try testing this out on a junked canopy.
Mark
Posted by Papa-Echo-64 on Saturday, April 1, 2006 3:11 AM
Dude! NOOOOO!!!!!
Anything but white glue!  Go to the store or a good arts and crafts shop and buy that CLEAR shelving paper.....you will love it!!!!
Got the HOOK painted tonight!   man its looking more like a Ch47-A every day!
    April 2004
Posted by Screaminhelo on Sunday, April 2, 2006 2:26 PM
I have used white glue with dish soap and food coloring with some success.  I would only recommend using it on a canopy with WELL DEFINED framing.  I have heard of someone using the new Glad cling wrap but I haven't tried it my self.  They claim good results using it just as they would ParaFilm.  I like the idea of the shelf paper.  You can use a whole piece for many window panels and the frosted finish would help to define come of those smaller frames.
Mac
Mac
I Didn't do it!!!
