Woot wrote: |
Also is there a set side of the helo to place the .50cal and Minigun or do they swap them around to suit?
Actually, I've seen more configurations with the minigun on the right side, and .50 cal on the left. There are plenty of references with either configuration, however, and they both would be acceptable. You might also want to consider throwing an M240G in the mix.
If you're planning on doing a modern USMC Huey in Iraq, then I will highly recommend Cobra Company's resin conversion and detail set for the Panda model. It's an absolute must-have in my book. Here it is: http://www.cobracompany.com/35012.htm. And while you're at it, their UH-1N weapons set is an absolute must-have as well. It includes the .50 cal, minigun, mounts, ammo bin, chute, and rocket pods: http://www.cobracompany.com/35013.htm.
Good luck.
