Trumpeter 47D - A in D clothing
    June 2006
Posted by fraighttrain30 on Wednesday, June 7, 2006 10:17 AM
I looked at the “D” this weekend in a Denver hobby shop.  The kit is has room for improvement, a detailers challenge!  Most of the items listed here are 30' type, that is from 30 feet or more, you'll be able to see it or notice that it’s not there.
From the front office back…
For the most part the cockpit is that of an A with what looks like a revised panel and center console.  The overhead console and PDP’s, Power Distribution Panels that flank the seats are for the A and undersized for the D.  The overhead is just wrong, as the D panel stands proud of the cabin roof, it’s about 2 ½ - 3” thick.
Heater closet, well you get the heater, but not the cargo winch.  This compartment is usually “open” and is rarely covered by blankets.  Avionics shelves, wrong stack, wrong radios.  However this is covered up all the time in the D for cooling purposes and is not that great a problem unless you want to depict he bird undergoing preflight or “Daily” maintenance inspections.  The control closet, left of the Jump Seat, is always closed up, again for cooling.
Cabin area.  Well it would have been nice to have some seats.  Hooks generally never fly with the seats removed.  The only time they are removed is for one or two types of vehicles or during maintenance.  The Sound Blankets around the cabin roof are nice.  They generally stop at the ramp, but I have flown some birds with the aft set removed.  The Ramp area does not have any blankets, and the overhead doors to access the aft transmission are always closed for run-ups or flight.  You’ll also need to build a wooden “Flyaway Box” usually lives forward, just aft of or under the FWD Left rescue hatch.  In hot weather most of the Flight Engineers remove this window in flight and we keep the upper access hatch locked open.  If we have a fir in flight the areas are closed up as the wind currents in a Hook go from ramp to the cockpit.  If someone on the ramp looses their lunch, you get to enjoy it in the cockpit about 20 seconds later…
Ramp area, this should have been the jewel of the kit, but they decided to save lots of cash and leave it un-detailed.  The is a very busy area visually.  Cutting molds can cost $1000 - $1500 per cavity so do the math.
Underside, Well it has the tree hooks of a D, but overall the underside is for an A.  The Doppler and Radar Altimeter antennas are missing.  The Doppler antenna is about the size of a 15 Inch flat panel monitor, so it’s a big omission.  The Radar altimeter antennas are about 5” across and tan in color so they stick out.
Cabin Roof.  The breathers for the ERFS tanks are missing, Extended Range Fuel Systems, all D’s have them even if they don’t have either the old or new Robinson tanks installed.  In the Gulf (WW Dirt II) we usually flew with one Robinson tank forward of the mid hook and to the left side of the cabin.  Not sure what the configuration was in WW Dirt I.  If your doing a fat Cow you’ll need 3 – 4 tanks plus the pumps.  I also think they left off the GPS antenna.
Engine pods, the cowls look ok but the engines are a bit “odd” looking.
WEPS, you’ll need three M-60D’s.  On in the front right cabin door, one across from it in the Left Rescue hatch, and one on the Ramp as Stinger Gun.  Seating on the ramp gun varies from cushions to the pilots seat of a Beach Barron we stole it out of at Saddam International Airport.  Most of the folks just stole white plastic chairs out of the mess hall and we used those for the waist guns.
Rotors.  The “sag” looks good, but the dampeners are way undersized.  The D dampeners are about 50% larger than the A dampeners and visually they stand out like sore thumbs.
There are several other fiddly bits missing her and there.  To make this a “Real D” you will need some work.
While an inbox check shows it to be a great starting point, you will need to do a lot of research and updating to make it an accurate D.
As an aside I’ve flown D’s and accumulated about 500 hours in them over 10 years in the Reserves and an extended camping trip to the Mid East.
Bryan
    June 2003
Posted by Avus on Wednesday, June 7, 2006 11:02 AM
Thanks for the heads up.
Adding these details to the fact that I'm thinking to build a SOAR Guns-A-Go-Go bird, I think that it'll take me years to complete that build!
Klaus
Thanks to ImageShack for Free Image Hosting
    June 2006
Posted by fraighttrain30 on Wednesday, June 7, 2006 5:44 PM
My guess is they will eventually come out with an MH-47E or MH-47G.  The G has more lumps and bumps…
The shots below are a good referance
http://s11.photobucket.com/albums/a193/MikeB69/MH-47G/?start=0
Enjoy,
Bryan
    June 2006
Posted by fraighttrain30 on Wednesday, June 7, 2006 11:31 PM
A good resource for detailing the 47D is listed below, the -10
http://www.chinook-helicopter.com/Publications/Publications.html
This will help a lot in detailing the 47D, and to a degree even the 47E & 47G
Enjoy,
Bryan
    June 2003
Posted by Avus on Thursday, June 8, 2006 2:43 AM
Thanks, those handbooks will surely help a lot.
The walkaround was already posted but thanks.
Klaus
    April 2004
Posted by Screaminhelo on Friday, June 9, 2006 8:46 AM
Fraighttrain,
We didn't happen to cross paths for a couple of months about two years ago did we?  Maybe in the tikki bar behind pad 3? We replaced the -60 guys in '04.
Mac
Mac
I Didn't do it!!!
    June 2006
Posted by fraighttrain30 on Friday, June 9, 2006 9:44 PM
Welllll,
Not sure if you mean at a little border airstrip about 12 KM outside Iraq, maybe.
I was assigned to the 5-159 flying 47Ds.  I departed the wonderful Sand Box at the tail end of Nov 03, the rest of the unit in mid 04.
Bout the only thing I miss, aside from driving a 50,000 LB helo through Baghdad at 50’ was the relaxing days in the camp, under the camo nets at 135 degrees, smoking Cuban Montichristo's.
No 4 Tubos…
Now I did have a chance to get up to Anaconda on occasion, never needed an alarm clock as the locals were nice enough to wake us up at 4AM with their regular mortar serenade…
Bryan
    April 2004
Posted by Screaminhelo on Monday, June 12, 2006 10:30 AM
Bryan,
It looks like I just missed you.  We got there in early '04.  We didn't go quite as far as Anaconda, went to Al Hilla on a regular basis though.  We got to stay in the "friendly" area most of the time, got to know the Kuwaiti 500 better than I can stand.  I remember an FE whose name I think is Chris.  If I remember correctly, tell him the guys from Ga said hello.
Mac
Mac
I Didn't do it!!!
    June 2003
Posted by Avus on Friday, September 1, 2006 7:50 AM
Now that I have my Delta-Hook I'd like to know which publication contains information helpful to correct my helo.
The Chinook site contains a bunch of publications!
I downloaded the "TM_1-1520-240-10" and it has some useful figures for the "front office". But I'd need some sizes, mainly for the MH-47's larger external tank.
BTW similar manuals for the Blackhawk would be nice, too. Anyone got a source?
Thanks!
Klaus
    March 2004
Posted by Grimmo on Sunday, September 3, 2006 10:48 PM
what would it take to make it into a CH-47 "C" model? I would like to do a RAAF Chinook and not sure of the variations between the variour models.
