Lifting Power
    November 2003
Lifting Power
Posted by johncpo on Thursday, June 22, 2006 5:57 PM
Here's a cool idea for anyone building the 1:48 scale Osprey from several years ago and displaying it on a runway/tarmack diorama.
Find two electric hobby motors for the model, these can be found at some Radio Shack stores and possibly HobbyLobby. While assembling the engine nacelles install a motor in each, run the wires through the wings and out through a small hole in the bottom of the fuselage and down into the base of the display. You can conceal the battery for powering the motors away from the display as you decide. When powered up, the rotors on this will actually start to lift the model off the display.
 Feeder wires will have to be attached to the wires on the motors as these are never long enough for such applications. Also, hobby motors normally are rated for no more than 6-9 volts DC but this is suffciant to operate the rotors. The shafts on the electric motors can be fitted onto the rotors using empty Bic pen ink cartraiges,cut to about 1/4 of an inch long they make excellent adaptors for this sort of thing. Some extra fitting of these parts may be required but the results are worth the time.
johncpo
  • From: Modeling anything with "MARINES" on the side.
Posted by AH1Wsnake on Thursday, June 22, 2006 7:27 PM
Thanks for the neat idea, John.
But with no interconnecting driveshaft, I'm afraid the rotor blades may become out of sync as each motor would be turning seperately. Just something to consider.
Also, since I am lacking a 1/48 stabilization computer, I'd hate to have my model crash and burn -- taking out a bunch of other dioramas with it. Laugh [(-D]
"There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion."
    June 2005
Posted by SSgtD6152 on Thursday, June 22, 2006 10:59 PM
Y' not, it will be true to life.Smile,Wink, & Grin [swg] but too bad that thing is going to get a bunch of us killed, that is the bad part..
    January 2005
Posted by Heloguy on Friday, June 23, 2006 12:15 PM
So true, man.  They better keep those CH-46's only in partial mothball.
"You scratched my anchor!"
Posted by Melgyver on Friday, June 23, 2006 7:50 PM
I stopped on my motorized Osprey due to the "sync drive shaft" issue but will take some pictures of what I accomplished when I get home.  I finally learned how to post pictures.
Clear Left!
Mel
