hey guys just got a 1967 Revell AH-1G Cobra
    March 2004
Posted by Mikeym_us on Friday, August 4, 2006 10:41 PM
don't quite know if it is 1/32 scale though it is big and I only got it for 10 bucks at a local antique shop and it is completely unbuilt.
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
Posted by HeavyArty on Saturday, August 5, 2006 8:37 AM
It is 1/32 and it is a great kit.  To update it if you like, Cobra Company does a few update sets for it.  Fireball Modelworks also has a couple decal sets and an upgrade set to make it a late G model with anti-strella SAM set.
It is a pretty goor model straight out of the box too.  The pilots suck though and need to go to the trash.  I have made a couple of them and have another in the stash.
Posted by m1garand on Saturday, August 5, 2006 9:22 AM
Sounds like you got yourself a good deal! enjoy it!
    March 2004
Posted by Mikeym_us on Saturday, August 5, 2006 3:00 PM
actually I just happen to have a 1/35 scale  Vietnam War Helicopter crew from Dragon that just might work I just have to rework the paint on the Pilot and Copilot and hope that it will work.
Posted by HeavyArty on Saturday, August 5, 2006 4:17 PM
 Mikeym_us wrote:
actually I just happen to have a 1/35 scale  Vietnam War Helicopter crew from Dragon that just might work.
They will work just fine.  I put a couple pilots in one of mine from the DML Vietnam Helo crew.  They look great in it.
Good luck.
    March 2004
Posted by Mikeym_us on Saturday, August 5, 2006 7:58 PM
now to figure out how to do the gun sights that are on the helmet
  • From: Aaaaah.... Alpha Apaches... A beautiful thing!
Posted by Cobrahistorian on Sunday, August 6, 2006 1:23 AM
Mike,
The G model Snake didn't have helmet-mounted sights, just the M73 sight in the rear cockpit and the trapeze sight up front for the CPG.  The later models (S MOD, F) had helmet sighting systems, but nothing like the Apache.
In any case, I just pulled this one out of the "repair" pile tonight and did a little work on it.  Hope you guys like it!
"1-6 is in hot"
    March 2004
Posted by Mikeym_us on Friday, August 18, 2006 10:54 PM
well I'm going to either switch out the pilot figure with the extended right arm with the copilot from Academy's UH-1C or at least switch the arm out with the right arm from the same UH-1C copilot.
Posted by Melgyver on Saturday, August 19, 2006 6:41 PM
Jon,
Looks like you did quite a bit of "extra" detail work on that bird!
Clear Left!
Mel
    March 2004
Posted by Mikeym_us on Monday, August 21, 2006 1:13 PM
well has anyone noticed how identical the sculptings are for the Academy UH-1 crew figures are with the sculptings of the Dragon Vietnam Era helicopter crew figures. which means I can definitely swap arms between both sets. as for the "Trapeze" sight that was probably on the late model G early models most likely had the pedestal reflex sight though they may actually have had the crude versions of the "Monocular" sighting system which would explain the clear mounting on the nose which the kit instructions dictated as a headlight. hey any idea why the later versions of the Cobra deleted the 40mm grenade launcher?
Posted by Cobrahistorian on Monday, August 21, 2006 1:54 PM
Mike,
The "trapeze" and "pedestal" sights are the same thing.  The G model only had the floor mounted flexible sight in the front cockpit.  They did not have monocular sighting systems.  The only one that did was the AH-64 PNVS testbed Cobra that had the nose replaced by an early PNVS mount and turret.  That airframe is currently at Ft. Eustis, VA.  The clear mounting in the nose is for the landing lights on 1966, 1967 and early 1968 birds.  Mid-production 1968 and later birds had the landing light relocated to the fuselage underside and the clear nose painted over.  I've seen plenty of pics where the lights were removed from the nose and the clear fairing was left as is.  One that particularly comes to mind is "Satan 10" from the 235th AeroWeapons Company in Vietnam.  Instead of nose landing lights, it just had a piece of plywood sealing the back of the light compartment that read "Satan 10".
There were a few night vision systems associated with the G model Cobra, particularly CONFICS and SMASH, but neither reached production and neither was a sighting system.  The G simply never had helmet mounted sights.  As for the deletion of the 40mm grenade launcher, it wasn't replaced until the entire turret was replaced with the M197 20mm cannon.  The 20mm was a much more effective weapons system which allowed much greater standoff capability than either the minigun or the 40mm GL.  Plenty of S (MOD) Cobras flew with the minigun/chunker combination until they were withdrawn from service.
Hope that helps!
Jon
Mel,
Yep, did a lot more work on this bird.  It still has a lot of repairs needed, but its lookin pretty good at this point.
"1-6 is in hot"
Posted by Melgyver on Monday, August 21, 2006 2:39 PM
I've seen a picture of a "Snoppy" doll in the clear nose of the later birds.
Clear Left!
Mel
    January 2006
Posted by whiskey on Monday, August 21, 2006 5:41 PM
Geez I wish I had a scanner so I could share all of my dads pics when he flew snakes. You name it, G's, S(mods and prods), E's, P's lol, he flew it.
    March 2004
Posted by Mikeym_us on Thursday, August 24, 2006 3:39 PM
I'll try to get pics on the progress of the crew since I also started on the Huey crew as well. I figured since I had them out why not work on themSmile [:)]
forgive me if the images might be poor I don't have access to high end lighting
