side rigging for the 1/35 CH-47A???
    December 2005
Posted by viper_mp on Sunday, September 10, 2006 11:37 PM
Does anyone have a pic showing the side antennae rigging for the CH-47A?  I've nearly finished the build, and once it gets painted and decaled, I'll be at the rigging.  And the d**ned instructions dont show it.
Rob Folden
Secretary / Webmaster- IPMS Plastic Surgeons Member at Large-IPMS Hawkeye Modelers
Posted by Papa-Echo-64 on Monday, September 11, 2006 12:21 AM
Howdy Viper_MP!
 I'm sure that help is on the way.....Good question .....It is important because there are several ways the wires were strung and the A in Nam did have it set up different than the D.
I believe the Squadron book shows those details?
Trumpeter did not put much thought into MANY things on this kit....the one that I did not think about untill after I had everything put together was the entena mast....they do not glue in place very firmly and are a very weak point!
If I would have thought about it I would have made the mast out of brass rod or something and had them in place from the inside with more 'meat' if I may....to give them more support.   Its very difficult to handle the model (even with removable blades) without breaking those mast loose. I would do that part of the assembly VERY LAST after decals, weathering etc.
Straighten up and fly right.....
    July 2003
Posted by oldhooker on Monday, September 11, 2006 1:49 AM
Hi Viper,
Here's the standard HF Antenna routing:
Also, the "A" Models didn't have the long Dipoles like what's in your kit... they were short (which should resolve the fragile assembly problem)... example:
On some of the early "A's", there were UHF or VHF antennas on the lateral fuselage, on both sides....
Hope this helps,
Frank
Take care,
Frank
Posted by Papa-Echo-64 on Monday, September 11, 2006 9:44 AM
Hey Frank,
Where did that pic come from....the one with the crew member waving from the rear window....looks like a crazy moment Shock [:O]
    July 2003
Posted by oldhooker on Monday, September 11, 2006 10:19 AM
 Papa-Echo-64 wrote:
Hey Frank,
Hi Troy,
That picture was made by the FE & CE on one of the 147th birds while returning from a mission in Vietnam, 1968.       Crazy moment.... or boys will be boys! Big Smile [:D]
Take care,
Frank
    December 2005
Posted by viper_mp on Monday, September 11, 2006 10:36 AM
Thanks Hook.  Question, on the A with the shortened masts, does it have wires strung?  It looks like just the masts.
Rob Folden
    July 2003
Posted by oldhooker on Monday, September 11, 2006 12:04 PM
Viper,
Some used the HF Antenna's and some didn't.... and in some pictures, it's just hard to make out the wire between the poles.
NOTE: Here you can see the proper placement of the fwd dipole.... on the Trump kit, the recieving hole for the fwd dipole is too far back.
Take care,
Frank
