albymoore wrote: |
Any other areas that jump out at you, Frank?
Cheers,
Alby
Hi Alby.... (by the end of this, you may be sorry you asked! haha)
Naaa... the two biggies are the Fwd Pylon and the brow glass. (well, personally, an entirely new front clear piece would be nice, because of the mis-shaped brow glass, upper chin bubbles, and THICK post between the glass panels)
I've made the Fwd Pylon modification on one 1/72 Italeri kit, and the 1/144 Revell kit... which are the same molds as the new 1/48 issue. It's a daunting thing to purposefully separate such a prominent part of the helicopter, but afterwards, you'll be so glad you did because of how it improves the lines! ..................However, for those who aren't inclined to cutting/rebuilding, all is not lost.... you can make the build more visually pleasing by making the rim around the sides and back more pronounced with the addition of curved sheet plastic strip, putty & smoothed, and filling in the groove on the upper front.
Below is a diagram of the changes/clean-ups that I am going to do on mine: **I have digitally made the corrections in the pictures....**
![](http://gunsagogo.org/ach47ITALERIfixes2.jpg)
(1). Add strips of sheet plastic to the rim and putty/smooth the union.http://gunsagogo.org/pylon222.jpg
(2). Re-shape armor plates.
(3). Apply putty/fill in the forward part of the groove and round out the ends of the grooves forward of the inspection platform seam.
(4). Apply round piece of sheet plastic in the cabin heater exhaust.
(11). A wide seam needs to be opened here, braced on the inside by a piece of sheet styrene.
(Reference pic for 1 - 4, & 11... http://gunsagogo.org/armordetail1.jpg)
(5). Sand off the elevated rims around the window holes in the fuselage. http://gunsagogo.org/0002/0002/earlyNam/np1.jpg
(6). *Just make sure there is a rim at the bottom of the opening. (there was a 1.5" rim between the bottom of the opening and the top of the Pod fairing... *reference the pic below)
(7). MG swivels are way too high. http://gunsagogo.org/0002/0002/earlyNam/crazy82.jpg
(8). Use properly shaped blade antenna. http://gunsagogo.org/0002/0002/earlyNam/0058.jpg
(9). The upper inside rim of the chin bubble needs to continue straight to the windshield rim instead of curving inward. http://gunsagogo.org/0002/0002/earlyNam/0091.jpg
(10). Kit decal is too big, and it needs to be positioned underneath the door rim. http://gunsagogo.org/0002/0002/earlyNam/0049.jpg
(12). Position of Nav Light. **reference the two pics linked below**
(13). There was a piece of sheet metal at the top of the 40mm mount that curved up to join the fuselage. http://gunsagogo.org/0002/0002/earlyNam/0058.jpg
(14). Troy, you were right about this one! The aft/rear of the 40mm fairing needs to be trimmed away, filled, and sanded. (also, where the ammo chute goes into the top of the Chunker should be round, not squared) http://gunsagogo.org/0002/0002/earlyNam/0058.jpg
Wheeewwww....
Okay.... now for those who want to "Go for it", along with the modifications indicated above, here is a diagram of the items that will bring the fuselage into specs!
![](http://gunsagogo.org/ach47ITALERIfixes.jpg)
(15). Cut pylon just above the horizontal seam (leave base for reference and to smooth putty)... start cut at the back and work your way around. A hobby saw would work fine because they'll not be any mating surfaces on the exterior. Mount pylon on one or more internal devices (pieces of plastic), then before you attach it, glue pieces of sheet styrene along the inside of the fuselage cut, which will serve as extra bonding surface, and a filler for the space that will be puttied. Question: "But how high do I raise the pylon?" Here's a back room reference for that..... get something and measure/mark the distance between the bottom of the cockpit emergency exit door, to the rim where the upper glass begins.... (dang, that's confusing!!) Example: http://gunsagogo.org/pylonheight.jpg This distance is the same as the pylon height between the horizontal seam and the upper rim. ![Wink [;)]](/FSM/CS/emoticons/icon_smile_wink.gif)
(16). I haven't got the fix completely figured out on this one yet, but probably will have to thermoform new brow glass section that will wrap around the front pylon base to form the correct angle..... If you look at two profile pictures showing the brow glass in the comparison photo below, you can see that the KIT piece slopes at too great an angle from back to the upper rim of the windshield, where it should be a more gentle angle and then curve down to the top of the windshield. Also, if you compare again, you will see the angle of the front of the windshield is slightly different. (yes, a new clear front piece and a resin fwd pylon *from the seam up* would make this a most accurate depiction)
![Thumbs Up [tup]](/FSM/CS/emoticons/icon_smile_thumbsup.gif)
(17). Wipers: I know, this fix should have been included in the first diagram, but what the hey... ![Wink [;)]](/FSM/CS/emoticons/icon_smile_wink.gif)
Here's some side by side comparison shots of the aforementioned area's...
![](http://gunsagogo.org/comparisonshots.jpg)
Troy wrote: By the way......any news on those 'better' decal options? |
Hi Troy,
I'm currently painting reproductions of the artwork so they'll have good clean/crisp images to use for the production process. (big discount for doing this!) Once I get it finished and get me a couple sheets from it, I'm going to see about selling him the master.... or marketing it myself...? Hmmmmm ![Big Smile [:D]](/FSM/CS/emoticons/icon_smile_big.gif)
Hope this helps,
Take care all,
Frank
