Build a synchronized tandem rotor - I GOT IT!!!
    July 2003
Posted by oldhooker on Wednesday, January 24, 2007 10:39 PM
I went out in the shop to do some modeling tonight, but started doodling, and came upon an idea on how to synchronize the fore and aft rotors on any tandem configuration.
With these larger scale releases, there is room to "hide" the shaft cable and keep the interior visually accurate. I think I'm going to try this on my 1/48 Chinook?
Take care,
Frank
Posted by Melgyver on Thursday, January 25, 2007 4:18 PM
Frank,
Not a bad idea.  I used some coiled springs, like in a ball point pin but more flexible to make 45 degree turns for an Apache tail rotor.  I think in this case some direct gearing would work really well.  I used the gears on HO slot cars to make the 90 degree gearbox on the Apache and connect to the main rotor drive.  Never finished it but it worked.  Camera is "inop" so can't take any digitals to post.  Maybe I can resort to some drawing later!
Clear Left!
Mel
Posted by J.H. Primm on Thursday, January 25, 2007 8:35 PM
How about using a beveled gear arrangement?
I didn't check the sizes but you can get an idea of what they would look like here:
 http://www.smallparts.com/products/descriptions/gbb%2Ecfm
Jonathan Primm
Youngsville,LA
Posted by Melgyver on Friday, January 26, 2007 8:46 AM
Jonathan,
I think you are on to something!  That would work well I think.
Clear Left!
Mel
Posted by J.H. Primm on Friday, January 26, 2007 1:10 PM
 Melgyver wrote:
Jonathan,
Well, it was Frank who came up with the idea, I was just thinking of a way to construct a mechanism without having to use a flex shaft... Using these, it may be possible to get away with something simple like plastic, aluminum, or brass rods/tubing.
BTW are you going to be in Lake Charles this weekend?
    January 2006
Posted by PatlaborUnit1 on Friday, January 26, 2007 4:37 PM
Im headed to Lake Charles, see you guys there!
David
Build to please yourself, and don't worry about what others think! TI 4019 Jolly Roger Squadron, 501st Legion
    July 2003
Posted by oldhooker on Friday, January 26, 2007 11:43 PM
 J.H. Primm wrote:
 Melgyver wrote:
Jonathan,
No, no... I like reading the input and welcome all the ideas it spawns! Smile [:)]
I think building a working drive train wouldn't require much, except a piece of aluminum tubing (or even a plastic rod), and build/find 4 interlocking gears.    Providing each gear is the same size and the rotor heads are in position when connected, I think the configuration below could work....
I looked at the 1/48 kit pieces, and there would be room enough to locate the aft gearbox inside the buldge on the top/aft kit ceiling piece.    The top of the enclosure would act as the lower brace for the aft rotor shaft, so the bottom would have to be detailed up so the gear won't be recognized by a viewer.
 Thanks, and ya'll have fun at Lake Charles!Smile [:)]
  Frank
Posted by Melgyver on Saturday, January 27, 2007 3:12 PM
Love it when a "plan" comes together!  Who will be the first to give it a try?
Jonathan,
Yes, I plan to go to the Show in Lake Charles!
Clear Left!
Mel
    July 2003
Posted by oldhooker on Sunday, February 11, 2007 1:55 PM
Mel,
Thank you for planting the idea about using "springs"! Thumbs Up [tup]     I made a test stand of sorts and connected the drive shafts with three ball point pen coilded springs, and it worked flawlessly!!     The trick, given the length of the shafts and weight of the rotors, is lubrication, especially where the rain shields come in contact with the pylons, and at each point where the drive shaft passes through a support brace.       As long as each joint is slick, and each spring/shaft connection is tight, the rotors will be synchronized! Wink [;)]
Thanks again all, I think this is the way I will hook up the rotor system on this kit.      If someone wanted to motorize this configuration, the DRIVE gear should be installed at the shaft juncture box in the aft pylon.
Take care,
Frank
Posted by Melgyver on Sunday, February 11, 2007 10:11 PM
Frank,
I used the next size up of brass tubing to make a "bushing" to put in the shaft support and lubricated it with grease.  Glad my "expertise" is of some value!   I found some nylon "differential" gears at a local Hobby Shop used for R/C Cars and Trucks that show some promise.  Ony thing I will have to drill out holes for the small gears to fit on the shaft and the larger ones could easily attach to the main rotor shafts.  They stocked a variety of small gears that could be used to futher motorize the whole drive train.  The differential kit was only $3.  Sorry I haven't the time to draw out the gears.  Also my digital camera is "history"!
Clear Left!
Mel
    October 2005
Posted by AirMedical on Monday, February 12, 2007 1:06 PM
 I must say, I always enjoy the intelligent discussions you guys have.  I always say, two heads are better than one.  Sit back and watch the imagination become reality.  Very educational.  I dig the drawings!!!  Just like patent drawings.
I just never had the guts to do what you guys do.  I've thought about it and pondered as to how to go about it; but that's it.
 <>Hats off to ya’s!  And a salute too!
John
Hope to be dropping by more this summer.  Been hanging out over at ARC lately. More civilian modeling folks there.  LOL!
Hope all is well with everyone/
-The more I'm around humans, the more I prefer the company of birds and animals -Even though the voices aren't real, they have some pretty good ideas. -Here's your sign!
Posted by J.H. Primm on Monday, February 12, 2007 1:52 PM
 Melgyver wrote:
Frank,
Mel;
Which shop was that? Was it in Lafayette?
Jonathan Primm
    January 2006
Posted by PatlaborUnit1 on Monday, February 12, 2007 8:20 PM
Big Boys Toys on Fue Follet has a lot of that kind of stuff........I maystock up next time Im in there to try this on one of my Phrogs.......
david
Posted by Melgyver on Thursday, February 15, 2007 7:12 PM
Jonathan,
I picked it up at Big Boy's Toys off Kaliste Saloom.
Clear Left!
Mel
Posted by J.H. Primm on Friday, February 16, 2007 6:48 AM
Mel;
Thanks I go by there all the time...I know exactly where it is.
Jonathan
    July 2003
Posted by oldhooker on Saturday, February 17, 2007 12:12 PM
 Melgyver wrote:
Jonathan,
Hmmm... how about a part number or name of the item, 'cause I'd like to get me one too! Smile [:)]
Take care,
Frank
Posted by Melgyver on Sunday, February 18, 2007 7:32 AM
Frank,
I'm "feet wet" right now.  I'll check when I get back home and get the Manufacturer and part number of the "kit".  Since the parts are nylon I expect it to be "tricky" to drill a true centered hole in the small bevel gear for a shaft.
Clear Left!
Mel
Posted by Melgyver on Thursday, February 22, 2007 9:25 PM
Frank,
The parts kit I picked up a couple weeks ago is by TeamLosi.  Transmission Gear Bag, Mini T, LOSB1066, Differential Gear Bag.  The sicker with the same part number calls it Transmission, go figure.  www.teamlosi.com
Clear Left!
Mel
    July 2003
Posted by oldhooker on Thursday, February 22, 2007 11:47 PM
 Melgyver wrote:
Frank,
Thanks Mel,
    I'll go check it out, and probably get me some of them!   There's all kinds of possibilities lingering there, thanks! Thumbs Up [tup]
Take care,
Frank
