real H model downed by nylon kite string!?!???
    April 2007
Posted by Bounce19712 on Thursday, May 3, 2007 8:18 AM
http://www.akfiles.com/forums/showthread.php?t=23372
I didn't think that would bring down a helo.....
Posted by grandadjohn on Thursday, May 3, 2007 8:56 AM
Anything that can get into flight controls and bind then up(the rotor head) can cause a crash and sometimes it doesn't take much
    August 2004
Posted by Chief Snake on Thursday, May 3, 2007 10:55 AM
The gyroscopic stablizer bar on the top of the UH-1 rotor system is a key component in balance  of the forces exerted on the controls. If something causes this to bind, the control response becomes disrupted and when trying to land that's a pretty bad time to get a flight control malfunction. Be it known that crossbow arrows fired from below into the belly of UH-1's caused deaths and injuries to crewmen and disabled flight control linkages ( in the belly) to the point the aircraft either made emergency putdowns or crashed. They also punctured fuel bladders and caused fuel emergencies. The fuel bladders were manufactured to a standard of self sealing after a hot small arms round penetrated the bladder, not a crossbow stuck in them and maintaining an opening.
Cheif Snake
