why Cobra tail rotors swapped sides?
    December 2006
Posted by ziggyfoos on Sunday, June 17, 2007 3:29 PM
What was the reasoning for the early Cobras tail rotor swapping position over from port side to starboard?
    August 2004
Posted by Chief Snake on Sunday, June 17, 2007 7:03 PM
Better range of authority throughout the performance envelope. In easy words, it worked better.
Chief Snake
  • From: Aaaaah.... Alpha Apaches... A beautiful thing!
Posted by Cobrahistorian on Sunday, June 17, 2007 10:47 PM
They tended to "run out of right pedal" in certain conditions.  Swapping it over to the right side improved the aerodynamics considerably and greatly reduced the Loss of Tail Rotor Effectiveness ranges.
Jon
"1-6 is in hot"
    May 2005
Posted by CHRH53D on Monday, June 18, 2007 12:41 AM
pls be gentle on me if I'm wrong...but...didn't the moving of the tail gear box to the starboard side provide a second and equally important improvement---stress reduction of the tail (rotary rudder) gearbox mount bolts. Initially (port mounted) the tail rotor would have to pull on the fuselage for anti-torque/heading hold while starboard mounted gearboxes pushed against the fuselage during anti-torque.   I thought I remembered something about that from the 70s.
Brian
Posted by Cobrahistorian on Monday, June 18, 2007 5:32 AM
Brian,
I do believe you're right!  Hopefully Snakedriver will chime in on this conversation.  He was there when the change happened!
Jon
"1-6 is in hot"
    May 2004
Posted by albert_sy2 on Monday, June 18, 2007 8:39 AM
does this mean that the main rotor changed rotation direction?
Groovy baby
    August 2004
Posted by Chief Snake on Monday, June 18, 2007 9:17 AM
No, the main rotor stays the same. The gears in the drive box for the tail rotor were changed to reflect the repositioning of the gearbox.
Chief Snake
Posted by Comanche Test on Monday, June 18, 2007 10:38 PM
A little bit more detail - The cause of the loss of antitorque control under some conditions was the tail rotor blades rotating in the same direction as the vortex created by the interaction between main rotor downwash and the ground.  (You can see that vortex flow at the back of the aircraft any time a helo lands in dusty conditions.)  That meant lower airflow speed over the blade, leading to lower lift and lower total antitorque force.  To fix this, the tail rotor gearbox was rotated 180 degrees, with attendant relocation of fill openings, etc.  This caused the tail rotor to rotate in the opposite direction.  Flipping the whole mechanism over to the other side placed the TR blade rotating against the direction of the main rotor/ground vortex, thus retaining lift when engulfed by the vortex.  It was the simplest solution, allowing the retention of all the existing driveshafts and the tail rotor blades.
 Dan H.
On the bench: Not much right now, just getting started again.
Posted by Cobrahistorian on Tuesday, June 19, 2007 5:36 AM
So basically it got the tail rotor out of vortex ring state at high power settings!  Very cool
Got to sit in your old project a couple weeks ago, Dan.  Man that Comanche's cool!  I would love to have flown it!
Jon
"1-6 is in hot"
Posted by Comanche Test on Wednesday, June 20, 2007 9:53 PM
Hottest ship ever built - there are faster helicopters, but none of them have Comanche's maneuverability.  There are more maneuverable ships, but none of them are as fast as Comanche.  We used to start demo flights with a 200 knot pass, then come down the runway at 80 knots and do a 90 degree pedal turn and keep going at 80 knots sidewards.  Ah, the old days.......
Dan H.
Posted by Cobrahistorian on Wednesday, June 20, 2007 10:48 PM
200kts!
Bow [bow]
160 in the Apache is... interesting... but fun!
I can only imagine what the Comanche can do....
Jon
"1-6 is in hot"
  • From: Modeling anything with "MARINES" on the side.
Posted by AH1Wsnake on Saturday, June 23, 2007 5:33 PM
Interesting fact I just realized: the tailrotor for the AH-1Z / UH-1Y drivetrain is back on the port side.
Insights?
--Andy
"There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion."
Posted by Cobrahistorian on Saturday, June 23, 2007 9:46 PM
I just noticed that.  Apparently it is still rotating up and away from the front of the helicopter, same as the right side tail rotor, but as far as the tractor/pusher issue, I'm baffled.
Bears some looking into, I think!
Jon
"1-6 is in hot"
Posted by Melgyver on Sunday, June 24, 2007 11:30 AM
It may have to do with the new 4 bladed MR System on the Zullu and Yankee, the aerodynamics changed.
Clear Left!
Mel
    March 2004
Posted by MBT70 on Monday, June 25, 2007 9:12 AM
Note too, the airfoil camber on the Cobra tailfin that adds to the tailrotor authority at speed and reduces the pitch level and subsequent drag it induces.
Life is tough. Then you die.
    July 2007
Posted by leadfooterm535i on Wednesday, August 8, 2007 5:38 AM
I saw that video. Coooool stuff.  I wished the Blackhawk could do that without jerking around, it would make gunnery so much more fun. Our pilots used to try to replicate it, but it ended up being easier to come in and move towards the target at a 45 degree so we could light them up, nowhere near as fast of course.
U/HH-60 CE "Embrace The Suck, Phantoms!!!" "I work for Pedro!" Kris
