The best way to get a V-22 to rotate the engines and wings is to hover over uneven ground in a crosswind so the ground effect will create disproportionate lift coefficients, causing the rotors to have blades strikes against the ground. It will then flip over and the whole thing folds up into a neat little pile.
Or you can just recalibrate the throttle settings so than one side runs a little slower than the other and get the same result.
Or do a mildly extreme maneuver that overstresses the wing loading and twist the whole thing into a flaming pretzel.
Doesn't take much .....
