new to helicopters
    August 2007
new to helicopters
Posted by ronart on Sunday, February 24, 2008 12:03 PM
 I hate to ask a question that you have probably answerd before, but altho I've built many fixedwings, this is my first helicopter, a revell huey hog, how can I get the windows on top tinted? I have been all over the forum here and learned a lot, but cant find anything on that, and are the rotor blades od, or black?
thanks
Posted by JosephOsborn on Sunday, February 24, 2008 1:39 PM
Easiest way to tint the "greenhouse" glass panels is with clear green paint.  Tamiya and Testors make it, and I'm sure other paint makers have it, too.  You can also mix a little green food coloring into Future and make a dip or spray solution.
As for the rotor colors, it depends upon the time period and the particular example you are modeling.  The early rotors were OD on top and they transitioned to black on top during the late '60s.  There's no hard and fast rule, though.  You could paint one of them OD and the other one black if you want.  Then there's the issue with white ID bands on the rotors, but don't worry too much about things like that.  Since this is your first helicopter build, concentrate on modeling basics like fitting, filling, and painting.  Helicopters go together a little differently than jets, and you have to work more with subassemblies.  Use the Huey as a learning experience, and then the second helicopter model (and third and fourth, so on) you'll find all kinds of details to worry about :)
All opinions are Certified Snark-free
    February 2006
Posted by rescuehawk on Sunday, February 24, 2008 7:22 PM
I airbrush Tamiya Clear Acrylic Green or Smoke, depending on the requirement.
Usually I will thin it with alcohol (don't use Jack Daniel's).
Make sure to spray only the underside of the "glass", not the top side.
Seal it with a little future and you're done.
Here is an example of a HH-65 I did using this method.
click on pic to enlarge
Good luck,
Pete Brown
    August 2007
Posted by ronart on Monday, February 25, 2008 10:08 AM
 thanks for your help guys, I may get hooked on these helicopters, really like the looks of the huey
