Porkbits,
Resin isn't a nightmare -- it just takes patience, a keen eye, and a steady hand. If you feel you are ready for it, Cobra Company is probably the finest quality resin you will find. You won't have to deal with deformed parts or bubble defects.
One thing that anyone building with resin has to deal with is clean up of the parts, and removing them from the casting blocks. No way around that. Also, you will need to sand, test-fit, sand, and test-fit again to make sure the parts will line up properly. The resin producers get everything as close as they can, but ultimately it is up to you, the modeler, to make sure they fit to your particular kit.
Resin cockpits usually require a lot of test-fitting and alignment to properly seat the tubs inside the fuselage -- I wouldn't recommend that for a beginner. Putting on resin wheels is comparatively easy, and hanging ordnance is not too hard -- either one would be a good start.
Andy
