Large Update- 10/3 WIP- PG-117 Soviet Dock Diorama
    June 2006
Posted by SteveM on Tuesday, October 7, 2008 12:00 PM
Ian... you've really pulled off that goose / water trick. It looks fantastic!
Steve
Steve M.
On the workbench: ginormous Kharkov dio
    April 2008
Posted by smeagol the vile on Tuesday, October 7, 2008 2:11 PM
The duck is a german spy, get it!!
But really, that looks really good, the only issue I have with it, is it seems the guy is going to walk off the edge of the boat, he doesnt seem to be watching where hes going
    August 2006
Posted by IanIsBored2000 on Tuesday, October 7, 2008 2:20 PM
Thanks Bodge, PanzerGuy, Nick Steve & Smeagol.
Smeagol: I see what you mean about falling off the edge.  The figure in question is only temporarily tacked on for display purposes, and will most likely not be his exact final position.  Thanks
"Scanlon: work your knobby hands on the table in front of you, constructing a make-beleive bomb to blow up a make-beleive world."
    June 2008
Posted by birdmam on Sunday, October 12, 2008 8:06 PM
Wow!! i can only dream of haveing mine turn out like yours! one ? , what did you use for the grass on the shore, i'v been reserching grass and would love to know how you did it
Posted by Anonymous on Monday, October 13, 2008 8:50 AM
 IanIsBored2000 wrote:
Thanks from all of you!
The splahing water effects are a mix of 5 minute epoxy, clear caulking, CA glue, and strands from cotton sawb/ear cleaners/Q-tips coated in clear nail polish to make drips.
Doog:  You're completely right.  Somehow I missed that when I was planning the scene, but it should be easy enough to lay in some rough concentric circles around the perimeter of the boat's hull with more clear caulking.  The difficult part will be the areas where the hull's waves are spreading out perpendicular to those heading towards shore, and moving the water in all kinds of weird directions.  Still debating whether or not to put some water in the bottom of the boat and a guy bailing water with a bucket.
Very nice work, Ian---love the water effects!!! I might "steal" some of your methods for my current Dio WIP!!!
    August 2006
Posted by IanIsBored2000 on Sunday, October 19, 2008 6:15 PM
Thanks guys!
Birdman....I used a variety of grass on this project.  The tall yellowish patches are Woodland Scenices Light Green Field Grass.  The lower, greener grass is a "grass mat" from one of the companies like Noch or Silflor, can't remember which, but they're pretty similar.  I always had problems with my static grass standing up, so I tried a "grass mat".  They're essentially pieces of thick paper with longish static grasses somehow glued on so that every piece stands on end.  If I remember correctly, it's about $14 for like 2 square feet of it.  The only problem is since it all stands perfectly up, the border between grass and no grass is too clear cut and unnatural looking, from dirt to lush grass on a perfect line.  So I just scraped off a little grass from a seperate, unused area of the mat and sprinkled it along the border, which made the flow from dirt to grass more realistic looking.
Hope that ramble makes a little sense!
    June 2008
Posted by birdmam on Sunday, October 19, 2008 7:35 PM
Thanks, It all makes sense Ill have to try this "grass mat" next time.
    August 2006
Posted by IanIsBored2000 on Monday, October 20, 2008 4:49 PM
They're great to work with.  Plus, since they're all glued in a standing position to the mat, they don't come loose when you drybrush lighter shades on.  I'm still on the lookout for some taller grass mats, in the 10mm range to make convincing fields, I think the ones I used were somewhere around 4mm high, to give you an idea of different heights.  IMPO, anything below 4mm that isn't supposed to look freshly cut and maintanied, like a yard or city park, just doesn't look natural.
Now I'm giving myself ideas to make a dio of an overgrown city park/playground, that was long since abandoned after bombings dropped lawn maintenance to the bottom of the city's prioritities...weed covered swing sets and old rusty slides covered in leaves, with a ragged teddy bear or hat left to hint at the absence of children playing...now I'm just getting off topic.
    June 2008
Posted by birdmam on Monday, October 20, 2008 5:56 PM
This sounds like the way to go!! Ill have to buy some and try it, any specail way of attaching it or just glue it down with watered down whiteglue?
    July 2003
Posted by Dwight Ta-ala on Monday, October 20, 2008 7:00 PM
Definitely a stunning job. Love the water.
    February 2008
Posted by stick man on Monday, October 20, 2008 7:22 PM
Nice job so far Ian I realy like how the water is spraying up around the goose.
Smile [:)]
I'm 15 and I model I sk8board and I drum what could be better.
    August 2006
Posted by IanIsBored2000 on Monday, October 20, 2008 8:51 PM
Thanks Dwight & Stick Man
Birdman:  I just cut to shape with scissors and then glue with diluted white glue like you said.  You will probably have to do another thin layer of whatever ground material you originally had to cover the edges of the paper backing the grass sits on, and bury the grass into the dirt a bit so it looks like its growing out of it, not on top of it.  If you don't have any luck finding grass mats, let me know and I'll find out what company and website I got mine from.
EDIT:  They were either the Heki brand or Noch brand from this website I beleive: http://www.sceneryexpress.com/departments.asp?dept=1051  Cruise around that site and I'm sure you'll find some great stuff.
    June 2008
Posted by birdmam on Thursday, October 23, 2008 4:34 PM
Thanks Again! Found the Heki Grass mats On ScenicExpress and will be ordering shortlySmile [:)]
