Hey blitzer,
Check w/ Verlinden, they have static grass that comes in various shades. I know there is another company that does static grass but at the moment the name escapes me
. Also you may want to check in the train department at your LHS as well.
This is the way I go about applying my static grass. When I go to lay down the static grass I first will lay down the dirt(good ol mother nature). This helps to make the grass look more realistic. Most important I apply the dirt and then the grass and not both at the same time(drying time in between).
Then I'll proceed w/ the static grass. To apply the dirt/grass to the base, I mix a mixture of water and white glue(Elmers glue).
From there I apply it to the areas that I fell that need it w/ a medium width brush(make sure it is not a good one).
I wait for about a half hour between processes and after it dries, I tip it over and get any excess dirt/grass off before I apply my next application.
If you do not like the actual colour of the grass you could do this also to inhance the realism. I'll take various shades of greens, browns, yellows and tans and start to do the dry brushing. These colours will vary depending on what season you want to represent.
Hopefully this will help you out. If you have any questions please feel free to e-mail me at
Falcon174th@aol.com or
Falcon42177@yahoo.com
Flaps up, Mike
If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
