IMPERIAL LANDING PLATFORM - FINAL IMAGES
    February 2009
Posted by Skonch on Tuesday, April 14, 2009 8:56 PM
Hi everyone,
Well, this is my final set of images taken to commemorate almost 3 months of work, none of which would have been possible without the support from you guys!
Thank you all for posting. (God knows what I'm going to do next!)
Here is a link to the slideshow of images shot during the build and on location on Endor
http://www.flickr.com/photos/30029551@N06/sets/72157616471685709/show/
And in case anyone is interested, here are images of all of my creations so far. ENJOY!
http://www.flickr.com/photos/30029551@N06/sets/72157617781357772/show/
    June 2008
Posted by Hans von Hammer on Wednesday, April 15, 2009 8:02 AM
I hope I'm ok posting Scifi stuff here...
Sci-fi, Sci-fact, A diorama's a diorama, Skonch...
    February 2009
Posted by Skonch on Thursday, April 23, 2009 2:11 AM
 Hans, I've noticed that you like to keep an eye on what's going on this forum, you seem to have commented in every post I've looked at, giving suppot and expert advice along the way.
 You probably know this already, but I have to tell you for myself, your comments are not only very welcome and appreciated but they have also given me no end of encouragement.
 Thank you!
    February 2009
Posted by Skonch on Thursday, April 23, 2009 2:17 AM
Well, work has been pressing on. The gantry's are finished and mostly painted and the main platform has been covered.
Next the platform legs are going to be cut and th gantry's insterte and fixed. I'm having to think carefully about whether I'm going to use some form of adhesive or another methd of fixing. I'm using PVC drain pipe which doesn't like being glued. I've tried epoxy, but it seems to just peel off.
Any suggestions
    June 2008
Posted by Hans von Hammer on Thursday, April 23, 2009 11:39 AM
Have you tried PVC cement?
    September 2006
Posted by the Baron on Thursday, April 23, 2009 12:29 PM
Wow, Skonch, what a great project!  When I read the first post, it looked like you're talking about a 1/72 or maybe 1/48 scale project, but when I saw your shots of the bridge and the figures, I've gotta say, very impressive!  This will be a fantastic display when you're finished.
BTW, Hammer is right, if I were gluing PVC pipe, I'd use PVC adhesive, you should be able to get it at any hardware store.  I don't know how well it will adhere the PVC to other materials, though.  For something like a PVC to wood bond, for example, I'd probably use contact cement, the kind you apply to both surfaces, let it dry, and then put them together.  Only thing is, it's more or less permanent, so if you need to separate the parts, that would be tough.  Hence, measure twice, glue once.
Can't wait to see more progess pics!
Regards,
Brad
    February 2009
Posted by Skonch on Friday, April 24, 2009 9:13 AM
Brad,
Thank you for your reply, I especially like your comment "measure twice, glue once", I think that''ll be my motto for this project.
For adhesives I've got some 2Pack Epoxy both 5 minute rapid set and 30 minute set, they have been for fixing the plastic sheeting to the MDF.
 For PVC to PVC I've got some "Pipe Weld" (a search on Google suggested it) I've not used any yet though. I've also got a tube of 2Pack rapid set adhesive for plastics althouigh your suggestion of contact cement sounds much more appropriate.
My other solution is much more old fashioned...Nuts and Bolts, which may be the best solution.
Up to now I've been very good with materials as there has been hardly any wastage, so I'm a bit angry with myself for throwing money at environment destroying glues that I can't use.
Anyhow, today I've taken the afternoon off and am doing some wiring and applying primer to some of the parger parts.
More images very soon.
    February 2006
Posted by starduster on Saturday, April 25, 2009 10:42 AM
  Skonch, that was one of my favorite sets in the movie, that and the big dish, you've taken on a grand project and I can't wait for the build to continue, how big will this be when completed ? you are a craftsman very nice construction.  Karl
photograph what intrests you today.....because tomorrow it may not exist.
    February 2009
Posted by Skonch on Sunday, April 26, 2009 4:16 AM
If I said this thing is going to be to scale with the Star Wars Hasbro ATAT walker (the larger one with 4 legs) and to scale with the stadard figures you might get an idea of the size of it.
I'm just in the process of painting the landing pad section and I just have to assemble the leg sections and the whole thing will be ready for final effects painting and eletronics. It's gonna be a beast!
    February 2009
Posted by Skonch on Sunday, April 26, 2009 4:22 AM
To the Baron,
Your comment "measure twice and glue once" came at just the right time and has almostsaved the project.
I took it upon myself to rig up the lighting before I glued it all into the platform, I spend 2 nights soldering all of the little LED's to the wires, hooked up the battery and switch and.....Nothing! it didn't work.
So, I went back to the Maplin Geezer who had originally showed me what I needed and he had failed to mention that the LED lights have positive and negative (I had assumed that they were like Low Voltage lighting).
I have now rectified the problem and can now proceed.
It just goes to show that the input and support from experienced modellers here really helps!
    February 2009
Posted by Skonch on Sunday, April 26, 2009 7:35 PM
    February 2009
Posted by Skonch on Monday, April 27, 2009 2:09 AM
ADVICE NEEDED-
I am now at a the stage where I can think about the final paint effecs and weathering.
I am looking for ideas for the drybrush colour. At the moment the whole model is painted in a darkish grey. I am going to use a very gark grey/black for the oily marks and will use an arbrush to apply but I need something that will bring out some of the detail and provide a bit of texture. I was thinking about a duck egg blue and use a dr brush technique.
Any suggestions?
    June 2008
Posted by Hans von Hammer on Monday, April 27, 2009 11:44 AM
To get the highlights to stand out more, I usually apply a dark wash into the recessed areas, then drybrush the raised areas with the lighter shades of the base color...  However, with come colors, the opposite is true.. Wash with lighter shades, then drybrush with darker ones... Either way, you're adding depth and making the detail pop out...  Too often folks use one method or the other...  IMHO, you need to use both..
    February 2009
Posted by Skonch on Monday, April 27, 2009 3:23 PM
Thanks Hans,
The issue with this model is that the ageing needs to be subtle. I guess that the structure would have some weathering in the recesses, a bit like a patina.
I'm definately going with your recommendation though.
Here is the first completed leg section minus the weahering/panel lines.
    September 2006
Posted by the Baron on Tuesday, April 28, 2009 11:44 AM
Progress looks great Skonch!  And you can't go wrong with Hammer's method.  Just remember, patience, and keep checking your work.  Have you thought about using chalks, too, for some weathering?  I love how easy they are to use.
And thanks for the kind word for my "measure twice" rule.  I have to admit, though, it's actually an old woodworker's rule (well, young woodworkers use it, too Big Smile [:D] ).  It takes only one ruined piece of oak or cherry to drive the lesson home.
Yes, your platform is going to be a real stunner when you're finished!
Regards,
Brad
    February 2009
Posted by Skonch on Tuesday, April 28, 2009 12:11 PM
Hans & Baron,
With this model it's hrder to do a wash as the paint isn't easy to rub off. I've found that if I spray the plastic primer from a distance it sticks to the PVC surface much better, but it creates a rougher paint surface that is harder to apply a wash to.
This is what I've done. I've airbrushed a dark colour first (thanks Hans), then I've dry brushed my own mix of light brown and muted red to look like rust. I've then dry brushed a light grey. Since taking these images I've also given the surface a ligh coating of the original colour to ease off the weathering a little.
    April 2009
Posted by deafpanzer on Tuesday, April 28, 2009 10:10 PM
WOW!  This is REAL AWESOME!  Any chance I can bring my two boys over soon?  They are real into Star Wars too!  Smile [:)]
 Will you add some LED lights to the diorama next?
Andy
    June 2008
Posted by Hans von Hammer on Tuesday, April 28, 2009 11:52 PM
Just a tip for future reference on washes.. They're best applied over gloss surfaces as the smooth finish allows for more capillary action and and easier wipe-down... Then shoot it with clear flat and start the drybrushing... Shoulda tipped you off earlier, sorry 'bout that...
As for the build, WOW!  I didn't have a clue on the size until you posted the wide shot with the couch!
    February 2009
Posted by Skonch on Wednesday, April 29, 2009 2:12 AM
Thanks Hans!
Yep, I kninda knew that a wash was going to be a problem (but I see where you were coming from), I only recently discovered the wash tecnique when I did some experimentation with some acrylics but it is now my preferred method for adding oil effects.
Thanks for keeping an eye on my post.
Regards,
    February 2009
Posted by Skonch on Wednesday, April 29, 2009 2:13 AM
+++UPDATE+++
I've now been working on the lighting, G+d it's fiddly! In each half I'm fitting 4 x red LED's in the support pillar and 8 x blue wide spread LED's in the platorm, 4 facing upwards and 4 fitted to the underside close to the pillars. Here is where I'm at!
    February 2009
Posted by Skonch on Thursday, April 30, 2009 2:11 AM
At last I can see the light at the end of the tunnel!
I've painted all of the parts and am finally happy with the finish, the last thing I did was to coat the whole thing in automotive lacquer to give it a metallic sheen.
I've just got to make the central Gantry and because the whole thing is designed to be assembled and pulled apart I've decided to make it out of Foamcore and clad it in plastic sheet. It will be fixed to the model by Velcro for ease of use.
Here are the updated images:
http://farm4.static.flickr.com/3406/3488321354_199ff71678_b.jpg
http://farm4.static.flickr.com/3599/3487507475_72da825678_b.jpg
http://farm4.static.flickr.com/3352/3488321044_9b0bc6a6e0_b.jpg
http://farm4.static.flickr.com/3313/3488320684_5d29d0f3ce_b.jpg
    September 2006
Posted by the Baron on Thursday, April 30, 2009 8:10 AM
Your weathering looks right on for the subject-probably weathered like a ship, and the garrison would have to keep at it constantly.
Starting to look like an ILM piece, great progress!
Regards,
Brad
    February 2009
Posted by Skonch on Thursday, April 30, 2009 10:23 AM
Thank you very much for your comment Baron, this is only the second time I've used an airbrush and I've only ever dry brushed aircraft models before.
I thought the same as you, it is most like a ship. Funny but painting this model made me think of the Ironclad ship Thunderchild from the album cover War of the Worlds. A WW1 battleship would be a great next subject.
J
    February 2009
Posted by Skonch on Sunday, May 3, 2009 2:40 PM
    September 2006
Posted by the Baron on Monday, May 4, 2009 1:31 PM
To quote Peter Griffin, "Aw, dat is AWESOME!"
    March 2008
Posted by FastasEF on Monday, May 4, 2009 10:53 PM
That is very very cool! I love everything about it. Can't wait to see it down in the woods and some final pictures.
Josh
    February 2009
Posted by Skonch on Tuesday, May 5, 2009 9:10 PM
Thanks guys for all of your support and love through this build.
I'm virtually finished, just a couple of minor details and I can finally get some sleep!
Here are my final pictures before I present the full diorama shoot.
    October 2008
Posted by padakr on Tuesday, May 5, 2009 10:08 PM
Wow! That is spectacular.  I look forward to the shots in the woods.
    June 2008
Posted by Hans von Hammer on Wednesday, May 6, 2009 6:31 AM
Yah, I like that...
    February 2009
Posted by Skonch on Wednesday, May 6, 2009 1:30 PM
Thanks Hans,
