base material for celluclay
    July 2014
Posted by batai37 on Tuesday, June 16, 2009 7:28 PM
O.K. I picked up a plastic poster frame that is of a suitable size for the dio I'm going to build, as per the example provided on Swanny's site. What I was wondering is what base material should be laid down first for the celluclay I'm going to use for the terrain to "bite" into? Surely you don't use the glass that came with the frame?
Posted by ajlafleche on Tuesday, June 16, 2009 7:34 PM
I always use a wooden base with holes drillied into it to increase bite. I don't hink Celluclay will adhere to a non-pourous surface (glass/plastic, etc.) since its glue is water based.
That said, you should build up any significant terrain with styrofoam, either sheets cut from blocks you buy or from leftover electronics packaging. Still, these won't adhere well to non-pourous surfaces.
    June 2008
Posted by Hans von Hammer on Monday, June 22, 2009 6:15 PM
I use plastic box photo-frames... I just rough up the surface with some 80-grit to give the Celluclay something to stick to...
I prefer those because I can glue them together to create any size base I need, they're cheap & easy to cut hole in for foxholes, ruts, etc, and they're hollow underneath for securing the models with nuts & bolts and can also hide electronics, if any..
I have had issues with the Celluclay lifting now & then due to warping of the wood trim around it, but a dollop of glue and a C-clamp fixes it pretty easy..
