KINDLY help me out on my first DIO....???
    March 2007
Posted by KAYSEE88 on Thursday, July 23, 2009 2:06 AM
hello friends....
yes can someone advice me on how to create the dug out you see on the box of this figures set my LHS owner gave me for FREE when my purchase came out to $185........???
i have never done a dio in my life....so any help is APPRECIATED!!!!!!
    May 2009
Posted by Pawel on Thursday, July 23, 2009 2:44 AM
Hello again, friend!
Now doing a little dio is not hard at all. What You need is a base, I'd suggest styrofoam. Using almost anything You can shape the styrofoam to roughly approximate the shape of the groundwork You are looking for. Then take some kind of putty (acrylics are probably best for this) and smooth the surface of the styrofoam. At this point You can also add the frame and don't forget things like footprints and so on. After the putty dries, it should be painted, then go for the vegetation - a subject in itself. Basically that would be it. Please check out my construction report for more details
www.vietnam.net.pl/M274moden.htm
I hope it helps, have fun and good luck
Pawel
www.vietnam.net.pl
Posted by ajlafleche on Thursday, July 23, 2009 7:27 AM
Pawel gives good advice but you need something to which to attach the styrofoam. Styrofaom is just not strong enouogh in the long run, IMHO. For something this small, get a 5X7 inch decoupage plaque at an arts and crafts store like Michael's or AC Moore. That should be about a dollar and will have a nice finished edge. Stain the wood with any color you choose. When this is dry, drill a bunch of holes in the base then tape the edges with masking tape. Get some styrofoam. If you don't have any around the house from an electronics purchase, you can get a block pretty cheaply when you buy your base. Cut it to the height and width you need for the raised section. Apply the putty as pawwel noted or use Celluclay and cover the styrofoam and the base to give it a nice organic feel, i.e. not too smooth...this isn't a paved parkimg lot or a green at the golf course. I wouldn't worry too much about footprints unless you're depicting partially dried mud or snow. To attach your figures and make it easier to paint them, drill a hole up one leg and superglue in a piece of brass or aluminum rod. You will also drill holes in the base to correspond to the rods so the figures won't fall over.
Here's a link to a base tutorial I posted a couple years ago.
    June 2008
Posted by Hans von Hammer on Thursday, July 23, 2009 10:16 AM
I use plastic box-frames for photos as a base... They come in various sizes, can be glued together, and are pretty cheap... To do a dug-out or foxhole, I just cut a hole in the plastic and drop cheesecloth into it, then liberally coat it with white glue, then "dirt"..
    June 2009
Posted by figure freak on Thursday, July 23, 2009 5:01 PM
I prefer floral foam coated in spackle
    November 2007
Posted by modelfreaks on Sunday, July 26, 2009 2:47 PM
Im doin this same thing for a Flak 88 right now and I built up the high ground with cardboard and put celluclay over it. It's similar to the foam method but the foam would probably be easier to use and shape.
-Brandon When something alines itself with something else, BAD THINGS WILL HAPPEN.
    April 2008
Posted by Stern0 on Monday, July 27, 2009 7:40 AM
Wish I had the foresight to add something underneath...I have always built up terrain with solid sheetrock mud.....takes a long time to dry....blocking it with something else is good advice...I also love Col. VH's frame idea....that way you can work down (smart) or work up (dumb) like me, which takes much longer and makes a very heavy dioSmile,Wink, & Grin [swg]...good luck!
Always Faithful U.S.M.C
    June 2008
Posted by Hans von Hammer on Monday, July 27, 2009 3:53 PM
This's one of my afore-mentioned dios with the hole "dug" into the plastic base... The Celluclay's only about 1/4 inch thick..
                   "Thanks..."
