For any of you interested here is the way I created my palm fronds.
Here is the pattern I use for the shape of the leaves...put in editor and strech it out a little, it is too short and fat.
here is a branch of leaves I used..Again they are unknown to me, if anyone does know...Note: see how the pattern is a little longer, than the file. Although any sized leaf bigger than pattern will do. Easier to work with if fresh.
Bend pattern in half, bend leaf in half and cut out shape with scissors leaving the stem intact. I varied the size by cutting at different distances from the pattern.
hold leaf (still folded) with stem away from you and make cuts up to the stem *BE CAREFUL NOT TO CUT STEM! Scissors seem to be the most controled way, but any razor knife will do. Make these cuts as close togrther as you can to make the "fringe" as thin as possibe...the thinner the more realistic it looks.
run your thumb on underside to open.
Thats it! Hope this helps you guys..any questions feel free to ask!
