Hey all,
Thank you all very much! This didy was a can of worms, adding and changing things. One area where I dropped the ball was the choice of paints. Which of course was picked up by the keen eyes that frequent this forum! Some crappy paint I stole from one of my kids "play coloring set". I started four years ago with the figs and that's all I had at the time. Big mistake.
The beach was easy....after the foam hardened, just glue and fine sand for the color. The first bit of dry land was done with bathroom caulk and brown "muddy" looking paint. The same caulking was used for the water. Differnt color blues to give the look of depth. The bathroom stuff isn't as stiff or sticky, easy to work with, slow to dry so if you don't like the results, just scrap off and start over.
The bomb bursts started with a half sheet of paper towl, rolled tight to look like a joint
glue a pop stick to one end, then hang it upside down to begin adding the bathroom caulk. Work from the pop stick down. Let dry and add more to the bottom (or top) to give it some width, and then turn it up right to add the higher water jets. If you use white caulk, no painting is needed. Look for these tricks on "You Tube", they may be deminstrated in Japanese, but you get the idea. The bullet rips were from clear silicone with a fine hole at the end. Just touch the ground and lift slowly. This stuff is alot stiffer, after if drys (over night?), snip off the very tips and paint. I tried this on land but had bad results.
All the figs came as is, one box of Gerries and two boxes of GIs. I will admit to ya that a few of the GIs are actaully German pieces, but "I see nothing!" Only the cassulites needed some gental minipulation (sp).
I'm just glad it's done so I can move on! Kurt
