This is to be my first dio. I've put figs with planes before, and put planes on ground work, but never everything all together. Not a big, full dio, just a plane and some groundcrew getting her ready to go.
For the plane, I used AMTs 1/48 A-20, and figs are from Monogram and Eduard.
The build, up to this point is here.
/forums/t/124657.aspx
For the base, I used a bit of 3/8" plywood and hammered on some trim. A spread on some drywall mud to make the ground a little uneven.
I sprayed that with some primer and randomly with some dark green.
I'll be adding stitic grass and some weeds later today.
The crew has got to get up on top, so I needed to scratch a ladder. I cut thin strips of styrene and pieced it all together.
And here's a few of the general layout.
Tis all for now.
